Hey, I have made the mistake of not checking the encoders on my servo's before oredering 3 gecko drives. The encoders are Harowe Servo 11-brc-300-G. Is there any simple circuit to convert these to an a/b digital signal? I have the schematic for the windings, they have six wires. Thanks. |
There are R-D converters (Resolver to Digital) . By the time you find one, wire it up, test it out, etc. You could maybe find an encoder for less than the R-D module. You could build an R-D circuit, but not as cheap as buying a surplus encoder. Pete |
the Sumtak, but they can be quite expensive. I have just come out with a resolver to quadrature converter toallow you to keep the resolvers, see http://pico-systems.com/resolver.html for more info. Jon |
| Just a short story about resolver/syncro signals. In an F-15 avionics shop a connector was replaced on a Roll Yaw computer off the aircraft. Post repair the unit passed all tests on the test station and was returned to service. A week later it came back written up for "Uncommanded inversion in flight". Pilot went to autopilot and was very quickly turned upside down. Seems 2 of the resolver signal wires were inadvertantly swapped during the connector exchange and the test station passed it because it only looked for a "null" signal on those two wires with zero deg setting. 180 deg out also gave a null reading. There was an up date to the test program to check at 0 deg and 45 deg to avoid future problems. By the way, the pilot was pretty hot about it... ![]() Steve |
| I have similar size 11 resolvers on some motors I have. I haven't yet, but I plan to make some adapters with a bearing and shaft inside which will mount where the resolvers were and accept a US Digital encoder on the back. There is just enough room in the housing to fit an E2 encoder. Good Luck Matt |
| Need Advice for Clone Conversion | lerman | Bridgeport and Hardinge Mills | 2 | 04-17-2006 01:48 PM |
| Conversion Done, Now Need CAM Software! | Otokoyama | Mini Lathe | 13 | 03-12-2005 09:28 AM |
| Digital Stop Mechanism | polyhedron12 | CNCzone Club House | 0 | 02-20-2005 08:54 PM |
| First Impressions for CNC mini mill conversion | CNCadmin | General Metal Working Machines | 4 | 11-16-2004 08:37 PM |
| possible cnc conversion on homier mini mill | WsW-WYATT | Benchtop Machines | 3 | 03-27-2004 07:24 AM |
