I have been trying to get these optic inturrept switches going for a few days. I did some reading on google searches and such, but to no ivail. The photo diode side wors fine if I supply my own light. I am using the interupt on m lathe spindle. I tried using seperate power supply before I got a resistor set from radio hack. I have multiple pieces so it's not just one that may be dead. I am a little stalled here and any help would be great. |
| If it is just the emitter diode side not working, if using 5v supply for e.g. , taking a ~220ohm resistor from pin 1 to 5vdc and pin 2 to common, it should work. The max LED current is 50ma, so if using it on a higher voltage, use ohms law to be well in range. Al.
| oh crap math,I got into machining so I didn't need math. alright I will work on some more today. I am about ready to shelve it for a few weeks. as an after thought, at 50 ma max current, I can't see how the ones I've tested with are not fried ,so I will start with a fresh unit so as not to add to frustration. Thank-you |
| If you did not use a resistor, they are blown for sure! Al.
| I am sure they are blown. I already tested a non touched unit and it performed flawlessly. It was drawing 10 ma, works for me. Now will be a slight task of mounting a good unit to the spindle. Different packaging may interfere with the assembly but that will be easy compared to this electrical adventure. But now it seems so simple. |
| Optical interupt switch implementation. | owhite | General Electronics Discussion | 26 | 07-26-2009 04:27 PM |
| Clock interupt or something? | thedoctor | Controller & Computer Solutions | 2 | 07-24-2008 05:41 PM |
| Looking for some Help Optic Lens | tklock | Laser Engraving & Cutting Machines | 9 | 03-27-2008 05:39 PM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
