Okay, I've got my outlet wired up. I am using a 30 amp breaker. A black wire leads from one pole, a white from the other and of course the ground goes to ground. I am using a heavy duty 2 pole air conditioning outlet. I run the black to one pole on the outlet, the white to the other pole, and the ground obviously to ground. Or should I combine black and white to one pole and run another wire to Neutral (I don't think this is the correct way, but want to be sure)? Does any of this sound incorrect? Now here is the real questions. I am using this outlet to run a fenner contrex m-drive to run my spindle's motor. The drive states that it can use 110-220 as input. So for my wiring, I want to run one pole of the outlet to L1, the other pole goes to Neutral/L2, and ground to ground. Does this sound correct? |
| If you are wiring the spindle drive from a 220v outlet, then you use the L1 L2 to 220v the neutral does not enter the picture, not in N. America, anyway. Do not connect any neutral to ground anywhere but at the panel. If you are connecting this up to 220vac outlet then you have 2 'hot' conductors and a ground. Al.
| Al, The motorhome bays around Grand Rapids Michigan, now all have 230 volt single phase plugs with ground and neutral. I dont know if thats new code or maybe just if your over a certain amperage or what. 230 single phase don't enter into my world very often. Buck |
| Or that is the way I interpreted it. In other words, if you are not using, or don't need the neutral, don't run it. Al.
| which 220v mig to get? | keebler303 | Welding, Brazing, Soldering, Sealing | 5 | 12-14-2006 09:06 AM |
| bp heidenhain 440v to 220v | CASTLEVILLE | Bridgeport and Hardinge Mills | 6 | 12-06-2006 04:40 PM |
| 220v acceptable range from power co.? | jderou | General Electronics Discussion | 1 | 11-06-2006 09:58 AM |
| Yet another 120v to 220v | Konstantin | General Electronics Discussion | 4 | 02-24-2006 01:57 PM |
| Gecko Factory outlet...and more | Bloy2004 | Gecko Drives | 27 | 12-30-2004 04:25 PM |
