Old 10-08-2004, 10:48 PM
Fabric8r is on a distinguished road
Help Building Tube bender
Hi im wanting to build a 3" mandrel tube bender. I need some help selecting the right motor, gear reducer, and controller. Any sugestions would be appreciated. I'm thinking of using a high torque servo motor " not sure AC or DC. I need help on how to controll the motor so I can stop it at certain angles.
Thank You,
Scott
Old 10-09-2004, 12:45 AM
vladdy's Avatar
vladdy is on a distinguished road
I assume you want to bend 'steel' or other harder materials...servo's are not going to work too well...
easier to do an electric over hydraulic with microswitches for end of travel..
unless you want to do several hundred a day..the drop a PLC front end on same basic power unit..
tried electic over hydraulic on my Hossfeld, worked great, but just did small qauantities [maybe two dozen max] of each bend angle..
cost is fairly minimal too..
enjoy..
vladdy
Beginner Troubleshooting and Building Considerations coherent FAQ of CNC Machine building 3 11-10-2011 01:27 PM
Building a stepper motor. tastefulasever Stepper Motors and Drives 13 12-11-2009 10:50 AM
Building My Second Router snazzyguy CNC Wood Router Project Log 10 04-30-2006 05:32 PM
Plasma tube notcher? ty1295 CNC Plasma and Waterjet Machines 20 11-12-2005 10:25 PM
How to weld plate to tube at 90 degrees? coolman Welding, Brazing, Soldering, Sealing 12 12-23-2004 02:03 PM
