Old 10-05-2004, 04:26 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Power up sequence
Hello all.
I have these SD200 modules I wan tot employ in a router.
Thing is, the modules have this specific power up / power down sequence that must be used.
To power up I must
1. apply 5V logic voltage with the ENABLE pin low
2. apply motor PSU
3. bring ENABLE up
To power down:
1. bring ENABLE low
2. disconnect motor PSU
3. disconnect logic PSU
I have done it manualy while testing and I hope to work an automated way to do so. Maybe with relays. Frankly I am not sure how. Anybody can help out?
Konstantin.
Old 10-05-2004, 05:05 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
You could try using a time delay switch. Either build one, I've seen schematics on the web. Or, use one from an industrial control system. I've seen loads on ebay. They can be had in many different time ranges and are adjustable. They usually come to fit din rails.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Obviously you'll wan't only a short delay.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
Need more power mvaughn General Electronics Discussion 49 06-15-2005 06:11 AM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-29-2004 11:22 PM
Traco TSL480 48V Industrial DC Power Supply 10A ullbergm General Electronics Discussion 33 03-06-2004 07:13 AM
