Old 08-07-2008, 01:20 AM
ftec is on a distinguished road
Buying EL components; Electrolytic Capacitor
I have some difficulties to find reasonably priced High Voltage Electrolytic Capacitors for appr. 22,000uF / 160V (or higher) locally. Futurlec sells 1000uF/250V for $3.40 and I could take 22 of those and make a matrix but it takes so much room. Anyone could recommend reliable (=well known) shops selling large el capacitors and other EL components internationally.
Thanks,
Risto
Old 08-07-2008, 12:13 PM
keebler303 is on a distinguished road
I always lurk on ebay until a good buy comes up on a bank of 'em.
Good Luck
Matt
Old 08-07-2008, 01:47 PM
cjmerlincnc is on a distinguished road
If you cannot find any high voltage ones you can connect capacitors in series, so if you found some 22,000uf @ 100v you can connect 2 in series which will handle 200v but roughly halve the capacitance.
Series capacitance is worked out as 1 divided by c1 plus 1 divided by c2 and so on.
So you would need 4 in total, 2 each in series and then parallel the 2 sets to get your 22,000uf @ 200v
If you see what I mean..
New Machine Build- Bleeding the Capacitor/s WannaMakeStuff General Electronics Discussion 4 09-25-2008 09:25 PM
what capacitor to use steptoey Stepper Motors and Drives 1 03-24-2008 08:55 PM
help with capacitor charles wilson General Electronics Discussion 6 02-13-2007 12:12 PM
PS Capacitor size,help shortbus General Electronics Discussion 11 03-25-2005 02:08 PM
how do I discharge capacitor? johnt General Electronics Discussion 7 03-16-2005 10:57 PM
