Old 08-07-2008, 01:02 AM
moldmker is on a distinguished road
Faceplate lettering.
Hello,
I'm involved in a reverse engineering project for 20 custom electronics enclosures.
The painted faceplates and buttons have black lettering/graphics which I need to replicate.
I have the artwork on file.
I need to explore different methods of applying the letters.
Searching web reveals laser printing/heat transfer method and laser/water decal.
Looks like the heat transfer method would allow me the closest duplication.
Many of you have much more experience in prototype panels than I do. Any other methods/comments?
Thanks,
moldmker
Old 08-07-2008, 07:27 AM
cam1 is on a distinguished road
Hi:
Sometimes we anodize the panels (after machining), and then engrave (on the VMC)through the anodized coating (.003-.005 deep) a carbide endgraving tool.
It looks trick, and is reasonably fast.
regards
Can't Fix Stupid
Old 08-07-2008, 11:35 AM
NEATman is on a distinguished road
moldmker-
Another option is to fill in the machined grooves with a colored epoxy to prevent oxidation. If you use a thin epoxy, and heat the part, it will flow nicely and come out almost flat with the top surface.
NEATman
Old 08-07-2008, 12:09 PM
I should add this, the faceplates are .035" thick steel formed to slight arch.
I think I will be limited to a transfer process.
Keep the ideas coming.
Thanks,
moldmker
edit: I just saw the other thread on inkjetting PCBs.
Had to chuckle, that was one option we joked about!
Old 08-07-2008, 12:15 PM
LOL
OK, so machine, then anodize, then engrave, fill with epoxy then roll form.
cheers
Can't Fix Stupid
Old 08-07-2008, 12:16 PM
Oops, forget the anodizing on steel.
Can't Fix Stupid
Need A Quote- CNC lettering on a MC cover.... IntrepidSE Employment Opportunity 9 04-09-2008 05:29 AM
Need Help!- Raised lettering, How ??? Mr. LocoMartin BobCad-Cam 4 03-29-2008 01:10 PM
Engraving small lettering. Rich05 Mastercam 14 01-06-2008 06:37 AM
RFQ: Aluminum lettering Sebastian Employment Opportunity 1 10-18-2006 06:08 PM
haas lettering cncsdr Haas Mills 3 10-12-2004 02:54 PM
