I am in the process of interfacing a special chuck package to a CNC lathe. I have used Direct Logic PLC's in the past and have had very good luck with them. On this project I have been asked to use an Allen Bradley MicroLogic 1000. I have not used that brand before and am having problems with the control logic. I have been able to figure the inputs and outputs out and have the basic idea but with the Direct Logic I can use an input to fire a control coil ( C ) and use that coil's contacts further in the ladder. I have not been able to figure the similar coil and contacts with the AB PLC. Any help or information would be appreciated. |
| What software are you using? You need to get a copy of the 'SLC500 and MicroLogix 1000 Instruction Set Reference Manual'. This explains the architecture and is complete with examples. Al.
| "the Direct Logic I can use an input to fire a control coil ( C ) and use that coil's contacts further in the ladder" Do you mean "further in the ladder" as in the same rung of the ladder, or a rung further down the ladder? |
| I am using the RSLogic 500 software and there was no good programming information that came with it. When I called and asked I was told I would need to take the class (what a shock, more $$$$$ needed) and that they didn't have one scheduled soon unless I wanted to schedule a onsite class ($$$$). The software CD has a manual on it and I have gone thru it, but it doesn't give very good discriptions or any true examples. I am just needing to find a good explination of the internal contacts and coils to be able to set up the ladder properly. Thanks again |
| The publication I listed in the previous post is AB # 956500-01. If you can get a copy from AB/Rockwell, I am sure it answer all your questions. It is quite extensive. I believe I got my copy free from the local Rockwell rep in this area. Al.
| Instead of C0 use B3:0/0 OR B3/0 How you have your options configured determines whether you use the first or second format. They are equivalent, it just displays differently. B3:0/0 - B3:0/15 OR B3/0 - B3/15 B3:1/0 - B3:1/15 OR B3/16 - B3/31 You could also use N7:0/0, etc. You may even be able to setup up your own files in the Micrologix, but I don't see that in the hardware manual. You can in the SLC500s. I too usually prefer the Automation Direct, although A-B has some nice features too. But next year, your $$$$ software may not work with the newest firmware release. You are paying the "insurance" for yearly updates aren't you? |
| Need Help!- x,y programming on sl 40 | Tim56 | Haas Lathes | 5 | 02-20-2008 03:01 PM |
| Cnc Programming Course | millmonkey1 | G-Code Programing | 0 | 02-20-2008 02:54 PM |
| CNC Programming | mikemill | General Metal Working Machines | 5 | 12-30-2007 02:05 AM |
| help programming | cody | G-Code Programing | 2 | 07-03-2007 07:53 PM |
| API Programming Anyone | Al_The_Man | Computers and Networking | 3 | 02-14-2005 08:31 PM |
