Old 09-29-2004, 10:22 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
How strong are 100oz steppers?
I'm curious what 100oz steppers equate to in foot-lbs or inch-lbs. Is it a measurement of torque even?
Someone please shed some light on this?
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 09-29-2004, 11:21 PM
cbcnc is on a distinguished road
Mvaughn,
I tested some of my motors using this technique: "How To Test Stepper Performance" .
The rating of a motor is supposed to be in oz./in. or ft./lbs. I have also seen them rated in the metric system.
So, a 100 oz. motor will hold 100 oz. hanging off a 1" arm. Or 10 oz off of a 10" arm. Or 8.33 lbs / .0833 ft.
The real specs though are in the torque curve. That is a graph that shows, that at a particular voltage, how much torque the motor puts out as you vary the speed.
Here are some torque curves for an Oriental Motor PK266-2A
Chris
Old 09-29-2004, 11:45 PM
mvaughn's Avatar
Moderator
In laymans terms 100oz steppers are 100 oz/inch or 6.25 lbs/inch?
Mark
Old 09-30-2004, 12:01 AM
Mark,
Yes you are right. My math was wrong.
Chris
Old 09-30-2004, 05:03 AM
arvidb is on a distinguished road
No, 100 oz is not a measurement of torque, it's a measurement of mass. However, it is commonly (IMO incorrectly) used as a shorthand for oz*in (also often and IMO incorrectly written as oz-in). And this is a measurement of torque, if you look on the "oz" as a measurement of force (I guess it should really be ozf*in or ounce-force-inch). The metric unit of torque is the newton meter (written Nm), i.e. a product of force (N) and distance (m).
This is wrong. The torque rating of a motor is supposed to be in ozf*in, lbf*in, lbf*ft, etc (here the f's indicate force as opposed to mass), or in the metric system Nm. Sometimes a hybrid between the metric and imperial system is used: the nonsense unit kg*cm. However, mass times distance (as in kg*cm) makes no sense; it certainly is not a unit of torque.
100 ozf*in divided by 1 in gives 100 oz of force, and 100 ozf*in divided by 10 in gives 10 oz of force, as you wrote.
For more information about this, see the CNCMechanics document in the FAQ section:
http://www.cnczone.com/forums/showthread.php?t=5866
Arvid
Old 09-30-2004, 07:26 PM
sol sol is offline
Gold Member
sol is on a distinguished road
100 oz.in. is just over ½ ft.lb....
For comparison:
A rechargeable screwdriver is around 640 oz in, they are advertized as 40 in.lb which is 3.34 ft lbs. That is easily overpowered by the user.
A basic 8 inch long wrench will allow you to strip threads rated at 20 ft.lbs or 3840 oz.in.(too ) easily.
Old 10-01-2004, 02:35 AM
*Registered*
ESjaavik is on a distinguished road
I'll just mention the benefits of metric here.
On second thought, no I will not. All of you already did that better than I thought possible.
Old 10-01-2004, 10:00 AM
mvaughn's Avatar
Moderator
I don't doubt that metric is much easier and better. However, when you've been taught to think in imperial all your life it helps to put things in those terms sometimes.
Mark
Old 10-01-2004, 10:33 AM
LOL @ Einar
When you think about it, it's incredible that NASA managed to put a man on the moon using the imperial system! It just makes my admiration for those people so much greater!
(I'm also brought up on the metric system, but have been forced to use the imperial system from time to time, and that has made me understand how clever the metric system really is.)
Arvid
Old 10-01-2004, 12:55 PM
mvaughn's Avatar
Moderator
It's more simplistic than clever. A base10 numbering system makes the most sense to us...
who knows, if we had 12 fingers instead of 10 the imperial system would be king!
Mark
  #11   Ban this user!
Old 10-01-2004, 01:14 PM
I think it's also clever. There is one unit for every quantity to be measured, and all units are defined to fit together very nicely.
And the prefixes makes it easy to express smaller/bigger quantities, while still making it possible to use exactly the same equations. (As opposed to the imperial system, where a change from f.ex. inches to feet requires a change of conversion factors.)
Arvid
Old 10-01-2004, 01:20 PM
mvaughn's Avatar
Moderator
Good point!
Mark
Chinese steppers & Xylotex limbo Stepper Motors and Drives 3 04-03-2005 07:44 AM
power of using unipolar steppers? dowling177 Stepper Motors and Drives 1 01-11-2005 08:10 PM
Need pulley advice for my steppers mvaughn DIY-CNC Router Table Machines 0 10-08-2004 01:02 PM
Just found some steppers! chuckknigh DIY-CNC Router Table Machines 5 08-14-2004 07:32 PM
steppers and current ullbergm General Electronics Discussion 0 01-29-2004 03:24 PM
