Old 07-20-2008, 12:12 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
DB-25 led test board
Does anyone know where I can find a simple LED outboard board, card, or unit ? I simply want to trigger LEDS on/off for testing on all the normal output pins.
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 07-20-2008, 01:08 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Here are several
http://www.pmdx.com/PMDX-112/index.html
http://www.cnc4pc.com/Parallel_Port_Interface_Card.htm
or you could just get a plain breakout board and add leds with 470 ohm resistors
http://tinyurl.com/599o5u
Jeff...
Old 07-20-2008, 01:39 AM
DrStein99's Avatar
After a few hours I finally found something decent. Ebay # 230272650873
Its an enclosed test unit, so I dont have to shuffle around with a bare circuit board all over the place being delicate; with extra stuff on it I dont want. Nothing beats a good reliable diagnostic unit.
smd and acc board-test transistors in situ? tom.jelly Bridgeport and Hardinge Mills 2 07-09-2008 10:32 PM
How to connect ELM Board and OSMC Board ? bigeye3107 Open Source Controller Boards 2 06-16-2008 06:26 AM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Just a test.. e_kakko Test Forum 0 02-23-2007 05:12 PM
Need to test a small board nervis1 General Electronics Discussion 11 12-05-2005 11:50 AM
