Proberly posted this in the wrong place but i am sure admins may stick it someware else etc.... Right so we have all built, or about to the cnc pcb(printed circuit board) drilling machine. GREAT But now what about the pcb tinning machine. Something i would like to try but havnt got a clue how to do. Hours searching for a cheep second hand one. No luck. Hours searching for any info on how one works or how to build one. No Luck. So i turn to you guys to see if any of you no how to build one. How does the rollers heat up ? Were do we get cheap rollers for this. Anyone got any designs ? Dont mine a hand turned one but havnt got a clue how to start about making one. Any help from u guys is welcome. Glen |
I decided like you to undertake the construction of a machine . Below the image of a small machine of mark CIF (French) of which you can be inspired to construir your . Since september 2004 had progressed you? Cordially Tonton75 Sorry for my bad English ! |
| Roller tinning is not difficult, at least not for small volumes. The solder is heated in a tank, or bath, which is usually heated electrically. A metal roller (usually steel I think) is immersed in the solder and a temperature resistant slightly compliant roller abover the PCB is used to apply pressure and guide the PCB through the slot. The PCB needs to be well cleaned before it is coated. Flux needs to be used and can either be brushed or sprayed onto the board or applied to the solder in the bath. The roller coating process will leave 'dags' all over th eplace usually. So the board then needs to be cleared, usually by using a hot air 'levelling knife' or reflow process. But to be honest, if you are only building boards for yurself, why do you need to solder coat them? Why not just clean and flux coat? There are plenty of really good fluxes around now (have a look at the Ketser web site). John |
Thank you for the answer, but my question more particularly relates to the detail of the realization of a machine. I already used the chemical method (too thin layer, produces expensive) as well as the method of coating (hard, lack of uniformity of the layer). The process of coating to the machine remains most professional..... The problem for a ` amateur' it is the price even for a small machine. Thus if somebody already produced such a machine, I am taking of all information. Cordially Tonton75 |
| A simpler/cheaper way to tin is to use diluted solder paste and "reflow" it. You can use plumbers solder paste which is fairly cheap and an electric skillet ($30 from target or about 5 from a thrift store).. Put the paste on thinly and then heat it up in the skillet. The thin solder paste won't bridge and won't stick to FR4. You might have to do several applications to get the right thickness. |
I use a similar process too - only I heat it with a heat gun - works great! Chris |
#10
| I believe it is water thinnable - go to http://www.mcmaster.com/ and search for "solder paste". scroll down about half way in the results for "solder paste with flux" 7683A4 is "ideal for tinning" according to their info there. (sorry, tried to link to the results page but it didn't work) You could use the Pb-free stuff but you'll need more heat and it's quite a bit more pricey. Can't help you on UK availability. And if you have a hot air machine/blower, that's just as good as the hot plate approach. Phil |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 09:04 AM |
| Having trouble cutting aluminum sheet | fastturbovet | General Metalwork Discussion | 40 | 06-14-2005 10:33 PM |
| drilling codes, which software? I want to drill my pcb with my machine. | NickLatech | DIY-CNC Router Table Machines | 1 | 03-16-2005 06:37 PM |
| Pcb Tinning Machine.?????? | glenfraser | General Electronics Discussion | 2 | 01-17-2005 01:03 PM |
| PCB engraver / mini-cnc machine | NickLatech | General Electronics Discussion | 3 | 12-26-2004 07:05 PM |
