Old 07-12-2008, 02:28 AM
tahoka is on a distinguished road
To Generate 12 V from 100-200V Supply
I want to make a circuit which generates 12 volt when input is 100 volts DC minimum and the o/p should remain constant 12V for maximum input of 200 Volts.
Using 7812 how do i step down the input voltage within permissible values.
Please need urgent help.
Old 07-12-2008, 08:20 AM
Al_The_Man's Avatar
200v is too high for the 7812, How much current is the 12v intent supplying?
I recently had to supply 12v electronic circuit on a 240vdc generator and I used a 1N4742 12v zener with a 7.5k 20w resistor and a 100µf cap across the zener.
The value of the resistor will depend on the max current you wish to draw.
This has been running continuously for several months now.
Old 07-12-2008, 04:23 PM
Gold Member
Mariss Freimanis is on a distinguished road
If less than 20mA is needed use an n-channel MOSFET preregulator in front of your 78L12. Drain to +200V, 100K resistor from drain to gate, source to 78L12 input and a 6V zener anode to 78L12 output, cathode to MOSFET gate. A reverse biased base to emitter junction of any small-signal bipolar transistor makes for a dandy 6.2V zener.
If more than 20mA is needed, a buck type switching regulator is the only choice.
Mariss
Old 07-14-2008, 10:46 AM
thank you for your help.
How to generate APT CL file using Mastercam? HELP!!! ejatt Post Processor Files 1 04-04-2011 11:13 PM
Connect 200V servo motor to 400V drive interflexo Servo Motors and Drives 0 04-15-2008 01:34 PM
Generate NC option Doug W Hypermill 4 01-14-2008 09:32 PM
Any controllers that can handle 140-200V servo motors out there? mbwittig General CNC (Mill and Lathe) Control Software (NC) 2 11-28-2006 01:14 PM
Best way to generate code? jderou BobCad-Cam 0 09-29-2004 08:37 AM
