I dont know what this is so I need your help fellas. Looks like encoder of some kind. Label reads:
As always manufacturer place has all the info right on the front page with a big label "Konstantin please read this, this is what you are looking for" just kiddin. Have not been able to get info on Stegman US/DE. I have 3 of those and if it can be used for my project I will use it but dont know what is it. Pics attached. Konstantin |
| Look like a resolver to me, you normally have an exitation winding 1&2 and a sine and a cosine winding. By design, they are usually fairly low resolution. Al
| tachus, Id love to hook it up but I cant really tell what the output is, what will tell me the output. Is it TTL logic pulses? Any circuit that will be able to count the output ? This is my first time with an encoder. To tell the truth I opened one of them just to see whats inside and of course the are some electronics, a couple of opto transistors maybe and a glass disc. Konstantin |
| That is a fairly strange object. It is an optical encoder with only one track and a index output. You need two tracks to use it as a rotary encoder -- unless you only go in one direction. With one track, you can't tell if the rotation has reversed or not. A resolver has 6 inputs: +/- sine, +/- cosine and +/- excitation. It does not need a power supply input. |
| Here is the Link to Stegmann http://www.stegmann.com/product/incremental/index.html If you hook up the 1&2 to 12vdc, if it is a line driver differential encoder you will get a 12v signal from each of the output which should be a square wave, but if it is open collector you will need a pull up resistor (~1k) to +12 on each output. The web site I believe is faxback or email for the info on encoders. Al
| OK, we're guessing, so let me too: It's an SSI interface (Synchronous Serial Interface). A clock input and a data output. You supply the clock at around 200KHz, and get back the position as serial data. You can get SSI cards for a PC, like this: http://www.addi-data.com/wEnglisch/p...pci-1710.shtml |
| Konstantin i was just guessing as well. Can show us a picture of the inside? Hook up some power to the plus and common. Check the voltage on all the outputs. If you don't get anything try 1k pull up resistors per Al's suggestion moving the shaft very slowly should see the output alternate low then high. If you get no voltage with the pull ups it's possible it is designed for use in a current loop. Try grounding the negative outputs with the pull ups on the positive outputs. |
#10
#11
Here are few more pics. Finaly a friend lend me his Cybershot. Look inside the misterious object. I unsoldered the opto thingie to move the pcb away. I believe there is a sort of 7805 IC just screwed to aluminum base, shown in the last pic. Konstantin |
#12
| Looks like there is a & b + index sensors with some of the parts (caps) missing for the b channel. It also looks like the output is capacitively coupled. If you follow the outputs do they go straight to the caps and nowhere else? You will need to bridge out the caps if this is the case. It also looks like you should be able to get the b channel working. What is the part number on the second chip? (not the 339). |
| one piece foam cutter | bladestalker | CNC Wire Foam Cutter Machines | 0 | 06-08-2005 06:36 PM |
| RFQ Custom Lathe Piece | Cold Fusion | Employment Opportunity | 15 | 04-05-2005 12:09 AM |
| Can anyone identify this program? | Velox_Skates | General CAM Discussion | 2 | 01-28-2005 12:46 AM |
| How to identify a Servo motor | Mr.Chips | General Electronics Discussion | 7 | 10-22-2003 11:42 PM |
| How do you Identify | CNCadmin | General Metal Working Machines | 2 | 09-11-2003 02:41 PM |
