I need a little resistor help please. I have a 60V power supply and need to choose voltage dropping resistors for the fans in the controller box. I have searched the net for examples and this seems to be common. Would someone check these values and let me know if I am on the right path? It just does not seem right to me. See the picture below. F2 and F3 are 24V .09A fans. F1 is a 12V .6A fan. F1 = V 24, I .09 F2 = V 24, I .09 F1 = V 12, I .6 R1 = V 12, I.078, R 154 Watts 1 R2 = V 12, I .678, R 18 Watts 8 R3 = V 36, I .858, R 42 Watts 30 Thanks for your help.
__________________ Mark DMG Designs League City, Texas |
| Are you sure you do not have 12v & 24v anywhere else (PC etc) that can feed these fans from? If not what you could do is eliminate R3 & R1, connect all fans in series with the two 24v fans in series across R2, make R2 a 95 ohm 50watt and also for safety connect a 48 or 50v zener across R2. Unfortunately it is a wastfull circuit as the fans are attempting to cool and you are producing wasted heat with the resistors. Al
| No, because of the inequality of the resistance between the 24 & 12 volt fans, this would result in almost 60 v (59.6) across the two 24v fans and the remainder across the 12v. Al
| check out http://ourworld.compuserve.com/homep..._Bowden/r2.htm might help ![]() hay if you want to use ac adapters i can sell you two that will work for 10 bucks. 1.5 amps each 12 and 24 volt. 1.50 shipping |
| Help on Voltage Reduction Resistor | foamcutter | General Electronics Discussion | 9 | 07-06-2008 08:19 PM |
| Need more power | mvaughn | General Electronics Discussion | 49 | 06-15-2005 06:11 AM |
| Using Zener Diode for Control Voltage? | jevs | Servo Drives | 8 | 03-21-2005 10:48 PM |
| 5vdc from paralell port, not enough??? | thuffner3 | General Electronics Discussion | 8 | 11-23-2004 06:07 AM |
| Stepper motor Voltage | metron9 | Stepper Motors and Drives | 3 | 11-15-2004 07:10 PM |
