Old 07-06-2008, 03:35 PM
cyclestart is on a distinguished road
a very basic fan question.
A broken cooling fan inside a Sieg mini-mill spindle control box. It plugs into a board with a transformer looking thing. On basic inspection it looks nearly identical to a computer processor fan I have kicking around.
The sieg fan is marked 12vdc 0.10 A
The computer fan is marked 12vdc 0.13 A
For some reason the sieg fan has slightly heavier looking wires. Maybe it's just heavier insulation.
Any reason this wouldn't be a direct swap? Assume nothing, I'm an electronics moron.
Anyone who says "It only goes together one way" has no imagination.
Old 07-06-2008, 03:45 PM
Al_The_Man's Avatar
I see no reason why it will not work, most PC style fans that run off a 12vDC supply are actually brushless, some machines that have 3 wire DC fans often have a fan blade sensor to indicate if the fan is rotating, but then you get a fault if the fan is removed or disconnected.
The heavier looking wires may be just heavier insulation type.
If it is the same diam, the air flow rate should be pretty close.
Old 07-06-2008, 06:43 PM
And it's a good thing you mentioned that. Looking closer the fan did have 3 wires. Knowing now what the 3rd wire was for, I simply clipped it. Works ok hooked up to a 9v battery.
Final test comes this evening
Thank you sir.
Very Basic Question H2ODiver General CAM Discussion 4 07-27-2007 08:51 AM
Basic Machining Question asperjack General Metalwork Discussion 1 05-25-2006 10:19 AM
Very basic electronics question. RotorRouter General Electronics Discussion 29 05-20-2006 11:35 AM
REALLY basic Question Dongle Mechanical Calculations/Engineering Design 25 03-14-2006 03:47 PM
real basic question. quammi Autodesk Software (Autocad, Inventor etc) 6 08-21-2005 03:28 PM
