Old 07-01-2008, 11:38 AM
jd@apm is on a distinguished road
Install
I'm installing 2 cnc machines. 1 mill, 1 lathe, both 3 phase, both have built-in transformers. I have 208V 3-phase in my building. My question is, without having to check proper phasing by trial & error, can I check phasing voltage at the transformer to see if my phasing is properly connected?
Old 07-01-2008, 12:10 PM
springlakecnc is on a distinguished road
Hi
I dont think so. if your spindle motor goes the wrong way, just change any 2 of the 3 electrical legs.
Remember, if the machine has a frequency drive for the spindle, the spindle should always go the correct direction, BUT, the coolant pump may be going the wrong direction, so you would still need to change 2 of the legs.
Good Luck
Install help djmickyg LinuxCNC (formerly EMC2) 9 12-02-2007 08:05 AM
How to install EMC2 cut more LinuxCNC (formerly EMC2) 11 07-18-2007 08:19 AM
EMC Install jhwatts LinuxCNC (formerly EMC2) 9 01-09-2006 05:36 PM
Install Problem crow TurboCAD/CAM 2 02-18-2005 10:43 AM
Turbo Cad/Cam install help Moondog TurboCAD/CAM 7 07-28-2004 02:07 PM
