Results 1 to 7 of 7
Thread: 5 or more axis Breakout?
    Feb 2007
    spain
    Greetings
    I am looking to install a 5-axis to my DIY router-table. Currently using a 4 axes breakout for a 3 real axis, one in slave mode. I have 4 motors with 4 Gecko drivers.
    I need a breakout board for 5 or more axes. Any idea?
    Tank's
    Mar 2003
    Shelby Twp, MI....USA
    Use two. I've never seen one that supports 5 axis.
    Feb 2007
    spain
    Forgive my ignorance.
    If I can use two breakout, I use two parallel ports?. The EMC or Mach software support two simultaneous parallel ports?
    If this is so, the solution is very easy. You know of any example?
    Thank you
    Registered Crevice Reamer's Avatar
    Mar 2008
    Some break out boards, like Tom Caudles's Mini IO, will let you piggy back another BO board without a 2nd parallel port. In fact, The Mini IO MIGHT just support 6 axis with the EZ Plug cards.
    CandC N C.com
    CR.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Greetings -- and welcome aboard!
    The CNC4PC breakout boards will support up to 6 axis. The c10 is very reasonable price as I recall. Now as to the slave motor -- can't you configure that in MACH? Don't know what set of programs you plan on - but MACH3 (and 2) are very popular and affordable.
    Here's a link to the c11 board -- don't know if the 10 is still available: http://www.cnc4pc.com/Multifunction_CNC_Board.htm
    hope that is helpful.
    Jim just a happy user of both -- not associated
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Mar 2003
    Quote Originally Posted by ger21 View Post
    Actually, I should say that I've never seen one that is setup or designed for more than 4 axis. The CNC4PC board mentioned above, is labeled for 4 axis, but has 12 output pins, so you should be able to connect 6 axis to it. Most breakout boards will be similar, but it depends on how they use their output pins.
    Sep 2003
    I have set the cnc4pc c11 up for 6 axis work -- have yet to figure out what and how to cut something with it now
    I really wanted to get to 4 axis for starters and it works well for that.
    :cheers; Jim
    1. what USB Breakout Board to by ??
      By dbss in forum General Electronics Discussion
      Last Post: 01-19-2008, 08:54 AM
    2. which breakout broad are u using?
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 01-11-2008, 12:26 AM
    3. Which breakout board to use
      By erkiwi in forum Stepper Motors and Drives
      Last Post: 05-05-2007, 03:08 AM
    4. New Breakout Board.
      By arturod in forum Product and Manufacturer Announcements
      Last Post: 11-25-2006, 09:15 PM
    5. usb to breakout box
      By smarbaga in forum General Electronics Discussion
      Last Post: 07-22-2005, 08:21 AM
