Actually just need some verification. Using powermax steppers 4.6a unipolar / 6.5a parallel bipolar. 2.71v 2 phase (6.5 *2) 13a * 3 motors (13 * 3) 39a. Using gecko 201's so I only need 65% of total amps (39 * .65) 25.35a I plan to use a 24v 12a power supply. Will this power supply work, seems to me that I will be under powered?? Or am I totally confused now!! |
| You can work it out this way - each phase uses 6.5A * 2.7V = 17.5 Watts. Total for 3 motors is 105 Watts. Your Power supply is 24V * 12A = 288 Watts. So you have plenty of margin. This is assuming the drives are 100% efficent and the steppers are stationary. When the steppers are rotating they generate back EMF which needs to be added to the 2.7 Volts in the caluculation. I haven't seen back EMF quoted by stepper manufacturers often but when it is it seems to be in the order of a volt or two per 1000 rpm. Still given the unknowns with a 180% margin over the basic calculation this power supply will be fine. |
| 1) Use the unipolar rating. 2) If the motor is round, multiply that by 0.66 3) Multiply that by how many motors you plan to use. For you that is Amps = 3 motors ( 4.6A times 0.66) = 9.1 amps from supply It the motors are "square", then Amps = 3 motors times 4.6A = 13.8 amps Mariss |
| Power Supply Question | BobLWeiss | Stepper Motors and Drives | 13 | 04-17-2005 02:27 PM |
| Power Supply ground question | chas | Gecko Drives | 5 | 04-16-2005 06:48 AM |
| Noob...Power Supply question? | andyfive | General Electronics Discussion | 2 | 04-08-2005 07:22 AM |
| FNG Power Supply Question | SteinAir | DIY-CNC Router Table Machines | 0 | 12-31-2004 09:31 PM |
| i got a power supply question | ljoe1969 | General Electronics Discussion | 21 | 01-11-2004 11:19 PM |
