Old 06-14-2008, 02:14 PM
MSGMachine is on a distinguished road
Question Power Supply Selection
I HAVE A 2 AXIS MILL WITH DC BRUSHED SERVOS THAT HAVE DIFFERENTIAL ENCODERS.
C. STALL TORQUE 14lb/in @ 7A
MAX RPM 4000
MAX VOLTAGE 100V
MAX AMP 34A
I AM THINKING OF RUNNING PHELPS CNC SERVO DRIVES THAT HAVE A MAX OF 80 VOLTS AND 20 AMPS.
I WAS ALSO THINKING OF HAVING A POWER SUPPLY FOR EACH DRIVE TO BE ABLE TO GET THE MOST OUT OF EACH MOTOR.
I NEED HELP SPECING A POWER SUPPLY(S) FOR THIS APPLICATION, AND WHERE I CAN GET SUPPLIES,OR ANY REC. THAT ANYONE HAS.
THANKS
Old 06-14-2008, 03:42 PM
Al_The_Man's Avatar
It is not usually considered necessary to provide separate power supplies, and it is also more cost effective to build one.
All axis motors usually do not draw maximum the same time.
I would go with a linear non-regulated.
There are many previous posts here on putting your own together, if you are fairly competent in electrical/electronics it will be fairly simple.
There is a ebay seller of Toriodal Transformers that can usually be adapted.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Help With Power Supply FLUTE HEAD General Electronics Discussion 7 08-03-2004 01:01 PM
power supply asd General Electronics Discussion 2 07-10-2004 04:53 PM
