Old 05-30-2008, 02:47 PM
bunalmis's Avatar
bunalmis is on a distinguished road
Coating material of hybrid circuits
I am planning to make this type hybrid circuits. I want learn the name of coating material.
Old 05-30-2008, 02:53 PM
daedalus is on a distinguished road
Search for pcb potting compound. Its stocked at most electronics suppliers, usually comes as a two part epoxy that you mix and apply. It provides your board with protection from damage / heat / water, and to some extent hinders reverse engineering, however you can always remove the epoxy with the right chemicals, so dont count on it for that.
Powder Coating nev25 Metal Finishing and Plating 1 11-26-2007 05:22 PM
Powder coating MBG Welding, Brazing, Soldering, Sealing 5 08-09-2007 01:26 AM
Lessons In Electronic Circuits epineh General Electronics Discussion 2 10-12-2006 05:05 PM
Simple driver circuits lazyscotsman Stepper Motors and Drives 3 02-28-2006 12:06 AM
Found some steppers circuits xairflyer General Electronics Discussion 0 11-08-2003 11:19 AM
