Results 1 to 2 of 2
Thread: adding power feed for x axis on a smithy 1220 XL
    Registered matridium's Avatar
    May 2008
    got a 1220XL from a guy who did not want it anymore, (for 150.00, and a 3 hour truck ride both ways!)
    However I am just getting into machining. I have already added a DC motor with controller to the 3-1, and also a Taculator.
    I want to know has anyone converted the milling table to a power feed table, how did you do it, what kind of motor did you use, controller and such?
    Even if no one has done this, has anyone done this on a 3-1 and have suggestions for the kind of motor to use, and controller. Also any incite on how to mount the motor to the feed screw since it does not protrude from the side. I want to keep the hand wheel for manual work but want the power feed as well. I know this can be done but tracking down the right kind of motor and contoller is the biggest hurtle right now. Next I will want to look at the mounting and maybe overload protection, micro switches for over feed protections and such. Thank you all and this is a great forum!
    Mike
    Jan 2006
    I am not sure what your machine looks like but I think the following would work:
    Take off the handle and put on a shaft coupler.
    Couple the leadscrew to a stepper motor with the coupler.
    Buy a stepper motor which is dual shaft (front and rear shafts).
    Mount the handwheel on the back of the motor.
    Use the excellent circuit posted here by Mariss.
    This should take care of the hard parts, you just need to put it all together.
    Good Luck
    Matt
  1. Replies: 0
    Last Post: 05-28-2008, 11:37 AM
  2. Useless Smithy 1220
    By ptulmer in forum Smithy
    Last Post: 03-11-2008, 04:14 PM
  3. Smithy CB-1220 XL LTD ????
    By bherr in forum Smithy
    Last Post: 09-16-2007, 08:58 AM
  4. I Converted Smithy 1220 LTD, to CNC
    By chris59 in forum Smithy
    Last Post: 04-05-2007, 08:01 AM
  5. Z Axis Power Feed... Need Help!
    By tom62 in forum Benchtop Machines
    Last Post: 01-23-2007, 09:18 PM
