Old 05-25-2008, 06:28 PM
jessbussert's Avatar
jessbussert is on a distinguished road
PS / Current Limiting Resistor Question
Hi Folks,
I just bought four old Superior Electric Slo-Syn unipolar steppers for next to nothing. I already have a Delagrange 4-axis board that is rated up to 10A (http://www.dtllc.com/files/4XCNC10Brev1.pdf) , and I have a simple power supply that outputs 26VDC at 2A. The steppers themselves are two each of the following:
ss250-200 / bm101010, 200 step, 225 oz/inch, 2.5VDC, 5A, 5ohm
m092-fd-322 / bm101025, 200 step, 200 oz/inch, 3VDC, 4A, 5ohm
My questions are:
1) Can I drop a current limiting resistor in series with the steppers and drive it with my existing driver?
2) If so, what value and rating of resistor?
3) Am I gonna fry anything?
I think best practice would have me buy a chopper driver. Unfortunately I'm broke and I already have this particular driver that I'd like to make use of.
Any help would be greatly appreciated.
Thanks,
Jessica
Old 05-25-2008, 08:24 PM
NC Cams is on a distinguished road
MOst if not all your questions can be answered via Bob Campbell's website wherein he explains hot to build a stepper P/S.
Old 05-26-2008, 09:32 AM
Thanks for the link. I'm new to this stuff and I'm nervous of toasting the driver, the steppers, or myself.
I don't need someone to do the work for me, but I'd sure appreciate it if someone could offer an "answer key" so I can confirm that I'm understanding things correctly. Plus, it would be nice to understand the reasons -why- things work the way they do.
For example, in Campbell's write-up, it says that the minimum voltage for the steppers is 20x their rating, and the maximum is 25x. I've heard this a number of times before but it still confuses the heck out of me. Why do the manufacturers rate the motors so low if that's not how they are used? Also, I've heard 20x, 25x, 30x, 40x, and more. Is there a tested value that is the best? Is it different for different motors? What are the pros and cons of the different values? How would a noob like me know what is the -right- answer?
I'm happy to post any more ratings or measurements for my motors if that would help, but I'd sure appreciate it if someone would care to mentor me through this first PS build.
Thanks!
Jessica
BTW: The PS that I built earlier started smoking... Ugh! It still meters out as expected, but I unpluged it quickly and haven't a clue what I did wrong!
-J
Current Limiting For Steppers waleed alhadidi General Electronics Discussion 10 11-11-2007 06:44 AM
current limiting R2 & R4? obscurity PicStep Controllers 1 07-17-2006 10:25 PM
Calculating current limiting resistors (I need serious help) Konstantin General Electronics Discussion 13 07-25-2005 04:10 PM
Current limiting resistor pyrojon General Electronics Discussion 8 04-19-2005 08:47 PM
Current limiting on homemade driver MrBean General Electronics Discussion 8 10-22-2003 03:02 PM
