Old 05-24-2008, 11:06 AM
bsharp's Avatar
bsharp is on a distinguished road
regenerative energy dissipater
I have a Mill that I retro fit with a PC control and Copley Accelus drives. I have had it up and running for a few months and have most of the bugs worked out. Now that I have gotten comfortable with running it I would like to increase the servo performance a little. Currently I can only safely run at slower rapids because of the regenerative energy pumping my Filter capacitor to high and tripping the built in protection of the drives. I was thinking of building something inexpensively. On the Accelus drives there are 5 volt digital outs that can be setup to trigger at a "warning" voltage. I was thinking of using that to trigger a resistor to drain the access voltage. I am sure some one has already come up with a similar solution for this and I am just looking for A prim example on how.
Old 05-24-2008, 11:53 AM
On commercial machines the voltage sensing circuit closes a relay putting a high wattage resistor acros the DC supply when the voltage goes above a limit. You should be able to rig the 5v to do that. On the machines I have the high wattage resistor is nothing more than a stove element; cheap, available in a variety of wattages and designed to get really hot if necessary.
Old 05-24-2008, 12:52 PM
bsharp's Avatar
Thanks GEOF
I have three 1 OHM 50 WATT resistors and a pretty big 75 amp IGBT that I think I could couple to an opto. The Power supply runs at around 84 Volts 30 amps and the Drive limits at a little over 90 Volts. I guess I will have to play around with it a little on the bench and see what I can come up with.
Use laptops to save energy? jimluu Environmental & Alternate Energy 3 06-18-2007 08:04 AM
FREE energy? Did you see this DennisCNC CNCzone Club House 3 02-07-2007 09:24 PM
Rotate pulleys using less energy. Jigar111 Mechanical Calculations/Engineering Design 2 12-03-2006 12:51 PM
What are you doing about energy prices? Netjams CNCzone Club House 17 05-03-2006 12:50 AM
step motor energy mechanicer Stepper Motors and Drives 5 02-07-2006 09:04 PM
