Old 05-21-2008, 12:56 PM
towertek's Avatar
towertek is on a distinguished road
USB Webcams for Centering
I really want to install my QuickcamPro USB 2.0 as a centering camera to my CNC Router. Problem is that the USB cables are way too short. I need at least 20'. I have researched this problem and have found the folowing things about USB2.0
  1. The theoretical greatest cable length for USB2.0 is ~ 15'.
  2. USB 2.0 webcams will not work with any of the wireless USB hubs, or any of the active USB extension cables. Bandwidth requirements are just too high.
  • Does anyone know of a way to get this camera extended just a few feet more?
  • Could I just solder on a longer lead to the camera?
  • Does anyone have any experience extending a USB1.0 camera out?
  • Has anyone use an IP Network camera as a centering camera?
Old 05-21-2008, 01:58 PM
jalessi's Avatar
jalessi is on a distinguished road
USB Extender
I am using a USB Extender to run my QuickCam® Pro 5000 Web Camera "Centering Camera"
It works perfect no gliches or dropped frames.
It uses CAT5, CAT5E, CAT6 UTP Cable for extended lengths up to 100 meters.
They sell for almost $100.00, I have a extra unit if you are interested for $40.00
Jeff Alessi
jalessi@aol.com
Old 06-01-2008, 08:16 PM
oreon_237 is on a distinguished road
or you can use something called an active usb extender, they arent as expensive as the network cable ones but they have set lengths. you do not want to make the usb cable longer, because that can really stuff up timings
A BETTER TAP WRENCH! SELF CENTERING! northernmach Product Announcements & Manufacturer News 19 08-28-2010 01:13 PM
Need Help!- Need help with Set-Tru chuck centering dpseafish General Metalwork Discussion 10 03-16-2008 07:14 PM
Self centering fixture Hack Mechanical Calculations/Engineering Design 18 07-12-2005 11:09 PM
Centering a 4-Jaw chuck gdl357 Mini Lathe 10 09-20-2004 05:24 PM
Centering blocks Hobbiest DIY-CNC Router Table Machines 4 02-09-2004 10:57 PM
