Hi As I am trying to keep the cost of my CNC machine as low as possible, I had a Television I was getting read of, so I opened it and removed the transformer from the inside, aslo kept other stuff just incase I might need them ![]() But the transformer has nothing written on it for size and stuff, is there any way of me finding out what the size in volts and amps is and if its any good for me to use (good size needed) Hope some one can help ![]() Thank you also for your time |
| That must be a fairly old TV if it still used a mains transformer! It depends if it goes back to an older Valve model or solid state version as to the secondary voltages, the only way is to identify the primary and secondaries and fire it up and check the voltages, the down side is they were not usually very big, power wise. Al.
| The tv wasnt really that old, it was just one of them standerd tv's not like a flat screen or anything, but thinking about it, it could be more hassle than its worth. Any ideas on what I might get a good transformer out of? as I might have something here, just trying to save as much cash on my cnc build as possible |
| The welders "may" come close to your ideal voltage also. There is an article in the magazine section here on the zone on how to rewind a transformer to suit this application.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| http://www.cnczone.com/modules.php?name=Sections ![]() EDIT: sorry I have a habit of doing this I think I found it http://www.cnczone.com/modules.php?n...warticle&id=27 that one? |
#10
| ok I have been looking around, the microwave couldnt be used as I dont have the old one anymore. So I looked in the welder I have and there is a massive and I meen like a 12" by 12" transformer in side well its like two in one as the welder has an high and low setting and I looked at a 12volt car battery charger this has one in also but what would be best to use, I dont mind using the welder as I can use the welder case for all the drivers etc also. any thoughts on witch would be best? EDIT: when I say big I meen like the one used in this in the pics near the bottom, but might be a couple of inches smaller http://www.dawntreader.net/hvgroup/welder.html |
#11
| What you have to watch with welder Txfr is wether it is from a stick welder or MIG, the Mig is usually OK but the stick has a magnetic shunt to limit the voltage out, i.e. they are constant current-variable voltage. The voltage collapses with current. The voltage they show in the schematic, looks like it is aimed at making a MIG welder. Al.
#12
| I have both a arc welder and a mig welder, I wanted to use the arc welder but like you say it will have shunts, but I like my mig better. looks like its to the drawing board on that again then, apart from I might still use the arc case lol what about the car battery charger ? its a big transformer like 5"x 5" lol I am a cheap skate |
| Connecting bipolar motors without knowing which wire is which? | Witsenburg | Stepper Motors and Drives | 1 | 05-12-2007 10:29 AM |
| X3 base size or minium bench size | kenrc | Benchtop Machines | 2 | 02-04-2007 06:50 AM |
| Help with knowing what I have???? | studysession | Stepper Motors and Drives | 1 | 08-12-2006 01:53 AM |
| Help me figure my transformer size | scheek | General Electronics Discussion | 13 | 03-09-2006 05:57 PM |
