Old 08-31-2004, 12:58 AM
Konstantin's Avatar
Konstantin is on a distinguished road
Protecting your home etched boards.
What can I use to clean the flux/paste and then to varnish my PCB'c?
Is this an advisable practice, I mean to varnish the PCB?
Konstantin.
Old 08-31-2004, 03:48 AM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
This probably isn't the best way but it works for me...
What I do is use laquer thinner on the solder side of the board and make sure I don't get it on any of the components. The I spray the solder side with clear coat paint.
I've done this on several small projects and it seems to hold up well and protect the traces from corosion.
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 08-31-2004, 09:03 AM
Al_The_Man's Avatar
There are commercial cans of both flux remover and the coating which is refered to as 'Conformal Coating' , this is a form of laquer (there is also conformal coating remover which is basically the same as paint remover).
Al
Old 08-31-2004, 09:44 AM
tachus42 is on a distinguished road
I scrub my boards with a water based foam cleaner from a spray can. And then rinse under running water and dry. It's called electrolube safewash 2000. Once the board is properly clean i have never had any problems with corrosion.
I wouldn't be afraid of trying some kind of detergent and water on a board. "Real" boards are washed with water these days and the components are ok to get wet provided you dry them promptly.
Old 08-31-2004, 11:21 AM
cliffhiker is on a distinguished road
Usually use lacquer thinner or other similar solvent... then
I've taken to tinning the copper traces with iron & thin coat of solder....
really quite easy and quick once you get the hang of it...
Old 08-31-2004, 11:51 AM
Al_The_Man's Avatar
I have found that if you intend using circuit boards in a shop that temperatures fluctuate over the seasons, I have seen some corrosion that occurs even if you clean them, I use the M.G. Chemicals 'Silicone Conformal Coating' it comes in aerosol can form as well as in a quart can. This gives some protection to corrosion as well as the problem you might get with metalic dust, this also does not harm the components like some petroleum based laquers might. You still have to wash the flux off however.
Al
Old 08-31-2004, 07:52 PM
gtrdude is on a distinguished road
You could use "Tinnit" to put a tin coating on the tracks on your boards. It's cheap and relatively easy to use.
Paul
How do you hook up limit and home switches? CNCadmin DeskCNC Controller Board 6 09-23-2007 03:34 PM
help with boards mocnc General Electronics Discussion 15 02-17-2005 08:18 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
question about 2 X 2axis boards Stevie General Electronics Discussion 5 03-14-2004 06:39 PM
