Old 08-29-2004, 08:34 PM
chozo is on a distinguished road
How many max amps per motor w/ HobbyCNC board?
4AUPC Chopper Driver Board Kits
3 or 4 Axis Unipolar Chopper control. NO "Ballast" resistors required!
Individual OR simultaneous control of 2/4 Phase Stepper Motors.
Accepts 5, 6, or 8 wire stepper motors only.
44VDC maximum input voltage, 12VDC or 24VDC minimum input voltage depends on fan voltage used.
3.0 Amps Maximum per Phase, 500ma (.5A) minimum. Adjustable throughout this range.
So, does this mean, if I used 3 motors, they could only be run at a max of 3 amps each? What if one motor is less than 3, can the others be more?
Is it possible to use a motor with a 4 amp rating?
Also, does the voltage rating on the motor matter?
Any help is appreciated.
Hooking up HobbyCNC board and motors to PC... jdbaker Hobbycnc (Products) 7 06-06-2005 01:10 PM
Question to builders of HobbyCNC board Catapultsup Hobbycnc (Products) 2 05-04-2005 11:11 AM
HobbyCNC 3 axis board build and review Jay C Hobbycnc (Products) 19 02-18-2005 10:22 PM
what voltage? i'm confused.. Stepper motors + driver board from hobbycnc Loterus Hobbycnc (Products) 8 01-26-2005 07:10 AM
hobbycnc board wjbzone General Electronics Discussion 5 08-23-2003 09:25 PM
