Old 05-12-2008, 09:54 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Manual Pulse Generator
The construction of my new Super-V router is nearly finished, and I have started working on the electronics. So far I have everything required, including a new Manual Pulse Generator. Here is a list of the main components I'll be using:
65VDC 6A power supply.
Four Gecko G202 stepper drivers.
Bob Campbell's Breakout Board Plus.
Manual Pulse Generator, model ESM80.2.100.12.R.R
Now I have wired one other router in the past, so I feel confident that I can hook this one up without too much difficulty. The problem I'm having is the lack of information as to the correct application of the Manual Pulse Generator to the breakout board.
I have contacted Bob Campbell, and he said the Manual Pulse Generator is compatible. He also said he would look for a document which explains how to add it to the breakout board. Unfortunately he has not responded. Now I'm in need of this information, so I can design the console which will have all the controls and switches for the router.
If anyone has any information as to the proper procedure and wiring, it will be greatly appreciated!
Widgit
ID:	59471   Click image for larger version
Old 05-12-2008, 10:47 PM
jalessi's Avatar
jalessi is on a distinguished road
LMS MPG
This document gives basic wiring not directly applicable to the Campbell product however it may help you.
Old 05-12-2008, 11:38 PM
One of Many is on a distinguished road
I've been kind of pondering how this was done in Mach, me-self; on the CNC4PC board.
The pendant I have is a Euchner with MPG, Estop and a few optional function buttons. The back burner was imagining what inputs would be required with a second port to utilize.
Thanks much for the thread and good info to match it.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 05-13-2008, 07:59 AM
Gold Member
Thanks for the replies!
Now I just realized I've been looking at the older .PDF file rev 1.7 of my breakout board, as I have a rev 1.8 board.
The rev 1.8 file indicates that the 6-pin jumper J23 is for Encoder, and the silkscreen on the board says MPG.
J23
Pin1 Isolated GND
Pin2 Isolated gnd
Pin3 Isolated to pin 12 of parallel port (in1)
Pin4 Isolated to pin 13 of parallel port (in2)
Pin5 Isolated to pin 15 of parallel port (switch)
Pin6 Isolated +5v
One the back of the MPG, there are four screw terminals:
1 5v/12v
2 0v
3 A
4 B
If I read the .PDF from MyLittleMachineShop.com correctly, all I need to do is connect the following pins:
Pin6 -> 5c/12v
Pin1 -> 0v
Pin3 -> A
Pin4 -> B
However it is unclear that 0v = GNG so I still need someone like Marris to validate my conclusion!
After this is wired in, it looks like my MACH3 software is the only way to use it, and to designate which axis to jog. This is a little confusing as well, as I have seen many a CNC console with an Axis selector switch or dial to choose which axis to move!
Thanks again,
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 05-13-2008, 09:10 AM
Can't tell you what GNG is, but I am confident GND should be 0v.
An MPG is an encoder with detents for operator feedback, used manually to produce a pulse stream. Pins with 0 and 5v power up the devices and outputs are A&B from the MPG.
You hit on why I posted that MPG picture. It has a 6 position axis selector which codes through 3 pin outputs used in a binary format. If you needed 6 selections you would need 3 bits to represent that to 3 inputs to a control. Since most of us are going with 4 axis max, this could be represented via 2 bits or pin inputs for 4 binary state changes. I was hoping to use the optional function buttons as X1, X10, X100 or Jog high and low speed.
I doubt there is enough inputs to take full advantage of all these functions individually. My thoughts were, in an effort to reduce the amount of pins required for extra conveniences.
Like in a 2 button jog function that re-uses the MPG inputs. One button could disconnect the MPG output signals and another set of buttons could send out a pulse stream on those A&B lines to function as a jog with variable frequency.
DC
Old 05-13-2008, 09:16 AM
jalessi's Avatar
Controling Axis with MPG
Wigitmaster,
A rotary switch or several momentary switches will control the selected axis.
A Second Parallel Port Will Be Required To Address All The Triggers.
The OEM Triggers need to be toggled.
OEM Trig #1
Select Axis X
OEM Trig #2
Select Axis Y
OEM Trig #3
Select Axis Z
OEM Trig #4
Select Axis 4
The ones below are for speed selection
OEM Trig #5
X1
OEM Trig #6
X10
OEM Trig #7
X100
You are correct zero (0) is ground.
Jeff...
Last edited by jalessi; 05-13-2008 at 09:26 AM. Reason: Second Parallel Port Is Required
Old 05-13-2008, 10:11 AM
Gold Member
DC
Oops!
Actually GNG was a (fat finger) typo, something my arthritic hands do alot!
Old 05-13-2008, 10:19 AM
Gold Member
Originally Posted by jalessi View Post
Wigitmaster,
Jeff...
Before I add a rotary switch to my list, is this selection process actually done in MACH3 ? There are several screen shots that indicate settings for an MPG in MACH3
Widgit
Old 05-13-2008, 10:57 AM
jalessi's Avatar
MPG Speed And Axis Selection
Wigitmaster,
MPG Speed and Axis Selection can always be controlled from within Mach.
The addition of physical switches will give you external (remote control) options as well.
Jeff...
Old 05-13-2008, 11:02 AM
Jeff,
So, I take it that the Pendant function takes up 7 pins for selections and 2 for pulses?
DC
  #11   Ban this user!
Old 05-13-2008, 11:11 AM
jalessi's Avatar
Pins
DC,
Seven pins to select each trigger,
+5 volts to trigger them high
Two pulse connections
One ground connection
Some BOB's get pulled down so then trigger would go low or ground instead.
Jeff...
  #12   Ban this user!
Old 05-13-2008, 11:22 AM
I am surpized the software doesn't take advantage of binary mode selection format to reduce the number of pins required. Leaving some for "other functions". 2 for pulses, 2 for axis, and 2 for speed.... sounds better than 9 dedicated.
DC
Tags
campbell, manual pulse generator, mpg
Manual Pulse Generator for K2CNC Mike Stevenson K2CNC 6 09-03-2009 03:23 PM
Adding a manual pulse generator to my home CNC glentner General Electronics Discussion 1 10-01-2007 09:30 AM
Pulse generator / controller boards for EMC.. which one? ewest LinuxCNC (formerly EMC2) 3 04-23-2007 05:53 PM
USB Pulse Generator support in EMC??? acondit LinuxCNC (formerly EMC2) 4 01-15-2007 06:42 PM
Manual Pulse generator? phantomcow2 General Electronics Discussion 10 07-23-2006 10:10 PM
