Hi All, The electronics dummy is back. I have a big old DC power supply, maybe 70-80 lbs; big transformer, diodes, big capacitors, and I think what is called a choke. It puts out 70 vdc and is rated at 20 amps. I also have a 10 amp Variac. Can I feed the output of the Variac into the power supply to achieve adjustable voltage output? I'm thinking about running some lower voltage servos. If I can do this, and adjust the output to about 40 VDC, what sort of amps can I safely output? I remember that there is some sort of isolation problem when using Variacs, should I take any special measures? Thanks, Ozzie |
| You can do it within reason, if you output the Variac to the input of the power trans. then it will be isolated, I would tend to look at taking turns off first. Technically your current rating would increase, but actually be limited to the wire size used by the secondary. Al.
| Al.
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 05:13 AM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| DC power from a Variac | jguillen08 | General Electronics Discussion | 10 | 03-13-2006 01:00 PM |
| power supply help | Gads | General Electronics Discussion | 1 | 02-20-2006 07:01 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 02:56 PM |
