Im looking at replacing my new lathes motor with a single phase AC or a DC motor for variable speed and have a couple questions. When a motor is marked for 90volts, can it use 180 volts, and if so what will happen. Someone told me that the rpms will be doubled at 180 volts if the motor is rated for 90 volts and a set rpm at 90 volts. If I go single phase ac, would I be able to use those variable speed control rheostats they sell for 20 bucks. I would be using a 3/4hp to 1hp motor and 110 volts. How do those work, and what do you lose with using them. Thank you |
| The SCR or PWM drives by KB or Baldor can run a 90vdc motor with the 120vac version or a 180vdc motor with the 240vac version. You can obtain manuals and info on both sites. You are better off to get these than the ones sold for DC Treadmill motors, which have a start prevention circuit that ensures you go down to minimum speed before start. Al.
| If you run a 90 volt motor off of 240v version you have to limit the speed pot, otherwise you may cause damage to the motor if too high rpm. Some models can be set by jumper. Al.
| Basic G-Code Question | Tazzer | G-Code Programing | 11 | 05-18-2008 09:21 PM |
| Very Basic Question | H2ODiver | General CAM Discussion | 4 | 07-27-2007 08:51 AM |
| Stepper motor speed\voltage question? | cwdance1 | DIY-CNC Router Table Machines | 4 | 03-28-2006 04:26 PM |
| REALLY basic Question | Dongle | Mechanical Calculations/Engineering Design | 25 | 03-14-2006 03:47 PM |
| Fanuc model 5 motor voltage question | Syp | Servo Motors and Drives | 1 | 01-23-2006 07:37 PM |
