I'm trying to start/stop a spindle in Mach3 using relay board. I don't understand why it isn't working. When I do the "toggle spindle" routine on the diagnostics screen described in Mach3 set up manual I can get my wires to go from 0 to 3.9 volts, and the screen indicates "input 1 " as functioning, but it won't start the spindle. I've tried both active high and low settings. But when I hook up 5 volts, or even 3.3 volts, from a seperate source to the relay's 5 volt input (instead of the wires coming from my BOB), it works. Can anyone explain this or help me? Thanks! Last edited by endgrainguy; 05-02-2008 at 12:38 PM. Reason: typo |
The relay requirese "5 volts". I tested it with a seperate power supply, one of those switch adjustable ones. It started at both 5 volts and 3.3. My meter says the wires coming off my BOB carry 3.9 V when switched "on" , but it is not starting the relay. Are not all volts of the same quality? I don't understand why this isn't starting. I"m not using a charge pump. I don't even know what a charge pump is. Do I need to use one to start 12 amp router with Mach3? Somebody out there must have a greater understanding of this than I do. It wouldn't take much I'm afraid! |
| Need Help!- Spindle won't start! | gamila | Fadal | 2 | 04-08-2008 11:07 AM |
| spindle start electrical problem boss 10 bp | Minnesota HD 10 | Bridgeport and Hardinge Mills | 1 | 01-19-2008 10:32 AM |
| spindle don't start in interact 412 | PRIOR666 | Bridgeport and Hardinge Mills | 0 | 01-17-2008 04:37 PM |
| Sometimes spindle won't start, and ... | david_geng | Syil Products | 1 | 08-31-2007 07:34 PM |
| Spindle will not start:HELP | raps | Fadal | 11 | 02-28-2007 02:32 PM |
