Old 08-23-2004, 08:45 PM
*Registered User*
treemagnet is on a distinguished road
electronic spindle switch
well my my router is working fine but now i want to have the spindle turn on and off by the software. i have a 5v relay which works fine on the router. Now it seems that the parallel port can't drive the relay directly so I think I need a small circuit to drive the relay does anyone have any ideas maybe a fet or transistor.
Tom
Old 08-23-2004, 08:59 PM
Al_The_Man's Avatar
There have been previous post on this subject if you do a search, I had mentioned using a fetlington 2n7000 that will do the job to drive a SSR or relay.
Al
Old 08-23-2004, 09:08 PM
*Registered User*
Thanks al i have been looking but so far no luck but i will keep trying
Tom
Old 08-24-2004, 12:09 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
You can get a TIP120 at radio shack (276-2068) that will drive the relay just fine. You will also need about a 1k resistor(271-1118) and a power diode like a 1n4003 (276-2068). This page has a diagram about halfway down the page showing how to hook it up. http://www.ee.ttu.edu/lab/robot/trans.htm You can probably do without the .1uf cap but it can't hurt to add it. Probably under $3 in parts even at RS prices.
jeff
Old 08-24-2004, 09:43 AM
Al_The_Man's Avatar
Link here http://cnczone.com/forums/showthread...92&page=5&pp=5
Al
Old 08-24-2004, 02:58 PM
*Registered User*
Perfect thanks AL
Tom
Old 08-24-2004, 09:58 PM
*Registered User*
Thanks again i got it up and running tonight
Tom
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 02:57 PM
spindle index, encoder, home/limit switch Wm McNett General Electronics Discussion 10 01-13-2006 06:39 AM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 09:41 AM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 01:51 PM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 11:46 AM
