Old 04-26-2008, 07:17 PM
georgeburns is on a distinguished road
Combine then split then combine?
I have some 12 strand 24 AWG plenum rated shield cable.
I have some Gecko 203Vs.
I have 8 wire steppers running in bipolar parallel taking max 3 amps each.
Would it be okay to use this cable in the following manner...
At the 203V output attach two wires from the cable... at the other end of the cable, attach the two to the appropriate two little wires coming out of my steppers.
How to combine two CO2 laser beams? jlew Laser Engraving & Cutting Machines 2 03-18-2007 07:29 PM
VBA - Import & Split large files NeoMoses Visual Basic 0 11-12-2006 02:38 PM
split question in Rhino turmite Rhino 3D 10 06-20-2006 07:33 AM
How to bore split pinion? Bloy2004 General Metalwork Discussion 13 11-18-2004 11:56 AM
