Hi all, ![]() Ok, I have spend some time going through various threads here at the zone so that I don’t ask the same question that’s been asked a million times before and end up upsetting any of the members. ![]() I’m currently half way through my CNC, 3 axis rougher construction and would like your opinion before I go too far: I have 3 x 640 oz-in motors in parallel (Keling KL34H280-45-8a that run at 6.3 amps max and 2.3 volts) run through 3 Gecko 203V. So my understanding thus far is: that the power supply should be around 46 to 57 volts ? and around 13 Amps without going overboard. Now I have read that daisy chaining of computer power supplies is Ok as far as boosting their power, so say I had 2 identical power supplies rated at 24V and 500 Watts, and once combined I was getting 48 volts at 1000 Watts, now I was always told that to calculate Amps you need to divide the watts by the voltage and in this case this would be 1000/48 = 20.8 Amps??? Is this correct. or do i need 4 power supplys to get 48 volts at 1000 watts??![]() Your direction would be highly appreciated. |
| it would be like if you put two batteries in series (daisy chaining), the voltage increases and you get the same amps. so if you had 2 24v batteries in series it would be like a 48 volt battery with the same current (amps). you would need 4 24 volt power supplies, 2 in series, and two in parallel to get 48v 1000 watts. or you could build a 48v 1000 watt supply. |
| Thank you for your repply skmetal7, that makes sence now..is it possible to tap in to the -12 and +12 and still get 24 volts at the rated current?? so say the power supply is rated at +12 V 10Amp and -12V 1Amp, would I get 24 V at 11 Amp?? (making the -12 volts Ground or 0 Volts) |
| oz/in to lb/ft to watts | 307startup | Linear and Rotary Motion | 11 | 10-01-2007 06:14 PM |
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 10:48 PM |
| Converting oz/in to Watts | mikie | Servo Motors and Drives | 8 | 10-06-2005 12:04 AM |
| Howto find input amps, from output amps on transformer? | sendkeys | General Electronics Discussion | 7 | 07-14-2004 07:13 PM |
| Amps, Volts, Watts, explained | ynneb | DIY-CNC Router Table Machines | 2 | 04-28-2004 06:11 PM |
