Old 04-25-2008, 11:04 AM
cnctiger's Avatar
cnctiger is on a distinguished road
linear encoder question
I have a RSF Elektronik MSA654 linear encoder. It has 5 wires that are black, white, green, red, and brown. Does anyone know which signals these wire colors represent?
Old 04-25-2008, 11:42 AM
Al_The_Man's Avatar
From their web site http://www.rsf.net/downloads it would appear these scales are low signal sinusoidal, not 5v differntial
For the actual function of the 5 connections, you could contact their support link.
They don't appear to show connections on the site.
The fact that there is 5 connections seems to bear out the sinusoidal type.
Old 04-25-2008, 05:26 PM
One of Many is on a distinguished road
I'd email or phone RSF and request the info. These come in either sine or square wave versions and may be defined as MSA654.xxx or by serial number.
I thought they used to include the connection diagrams in their PDF's. Not any more darndit!
5 wires sounds fine to me. +5v,GND,A,B,Z would be typical. If there were a way to view the reader head board and assertain the power connections, then view the signal type on an O-scope, out the remaining lines while moving slowly,.....good nuff?
The Z signal will either be centered on the scale or 35mm from each end.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 04-25-2008, 07:26 PM
cnctiger's Avatar
Al,
Thanks. I sent a request to RSF for more information but have not received a reply.
DC,
Thanks. I was also thinking of putting a scope on it to determine the signals but did not want to put 5V to the wrong pins.
Old 04-25-2008, 11:55 PM
I wouldn't do it without knowledge of what is on the circuit board that can clue you in to further research in the details. Like IC numbers, capacitor and diode connection points. Looking for hints will certainly reduce the risk if RSF doesn't come through or now wants you to pay dearly for that kind of information. Not likely but it is odd they have cleansed it from their PDF's.
Maybe you have more patience than I do. The old saying is curiosity killed the cat. I say, but it has nine lives! With good information and an ounce of confidence, at least one of those lives is in good hands?
DC
Old 04-26-2008, 08:00 PM
cnctiger's Avatar
DC,
I doubt that I have more patience. Just not enough time during the week to play. Curiosity did win over patience and I pull the read head apart. After trying to follow the traces and looking up IC info I came up with the following guess:
Black = V+
White = Gnd
Brown - Green - Pink = Signals
So I hooked up the scope and applied 5V. It Worked!!!
Final analysis:
Black = V+
White = Gnd
Pink = A
Green = B
Brown = Z
Thanks for the thoughts and the inspiration. I was wondering whether I was the only one curious (crazy?) enough to take apart a perfectly good glass scale just to find out what makes it work.
The glass is too big.
Old 04-27-2008, 08:34 PM
Originally Posted by cnctiger View Post
DC,
Black = V+
White = Gnd
Final analysis:
Black = V+
White = Gnd
Pink = A
Green = B
Brown = Z
See, there ya go! Glad to hear it all worked out for you. So, I take it the signals showed up as square wave quadrature?
When you get ready to mount it, be sure and place a .06-075 spacer between the reader head gap and the scale spar to set its alignment. Many are shipped with special alingment clips that are removed after the scale and head are all mounted. This keeps the read head from tilt, strain and lifting off the glass scale, losing the output signals at the head sensor. You also want the spar within .01 parallel over its length in 2 planes to the axis it runs with.
DC
Linear Encoder Information jlaiken2 General Metal Working Machines 3 07-28-2008 08:23 PM
sine wave Linear Encoder ?? Danii Linear and Rotary Motion 1 11-01-2007 08:44 AM
linear encoder wires ?? elpete0068 General Electronics Discussion 0 06-25-2007 10:38 PM
Question About Linear Encoder Signal Conditioning derekj308 General Electronics Discussion 6 05-05-2007 12:54 AM
Linear Encoder Question Verboten Linear and Rotary Motion 5 08-30-2003 03:04 PM
