Old 04-24-2008, 07:56 AM
AlainB is on a distinguished road
How to calculate the transistor base resistor value?
My parallel port output 4,8 volts. For instance, if I want to use a TIP121 for driving a stepper motor, I will put a 1K resistor betwen the base and the computer pin. Not because I know what I am doing, just beacause I saw it somewhere. If I don't put any resistor, it will work the same anyway.
Both ways could be good or bad, I don,t know.
Could you explain what is needed to calculate the right resistor values for any transistors used that way. I am looking for values for hard switching application only. If this information is needed, the transistors would be used as power stage for a 5,2 volts 1,4 amp. unipolar stepper motor
Here are 2 datasheets.
TIP121:
http://www.ortodoxism.ro/datasheets/...onics/4128.pdf
BUL45:
www.onsemi.com/pub_link/Collateral/BUL45-D.PDF
Thanks for any help.
Alain
Old 04-24-2008, 03:29 PM
pastera is on a distinguished road
The TIP121 is a darlington, so there are two diode drops in the base.
R = (Vin - 1.4)/Ib
Where
Vin = parrallel port outout (4.8v)
Ib = desired base current ( 10mA is fine for your application)
Aaron
X axis transistor failed...AGAIN Mr. Technical Bridgeport and Hardinge Mills 18 08-21-2007 06:16 PM
transistor substitution keebler303 General Electronics Discussion 4 08-25-2006 10:20 AM
Transistor Question DANIEL HALL General Electronics Discussion 17 01-07-2006 12:16 PM
transistor question scott m General Electronics Discussion 9 07-22-2005 06:38 AM
Calculate resistor value for g210 ??????? Biggermens Gecko Drives 0 04-25-2005 02:09 PM
