Old 08-17-2004, 03:03 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Im Waiting 4 Weeks For A Transformer
HELLO ALL, DOES ANYONE KNOW WHERE TO FIND TRANSFORMERS. Particularly
in a wide range of sizes. How about one with these specs: 20vac secondary with 12-15 amps output. I ordered from Plitron, but wow, 4 weaks. Places I've searched include Mouser, digikey. thanks matt
Old 08-17-2004, 03:08 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
http://allelectronics.com maybe?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-17-2004, 03:10 PM
CNCadmin's Avatar
Site Owner
nevermind they only go up to 5A
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-17-2004, 03:13 PM
CNCadmin's Avatar
Site Owner
he has 20a transformers "power supply 36V 25A $125 ( email me at dmauch@seanet.com I do not want to sell power supply kits to unqualified people." http://www.seanet.com/~dmauch/
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-17-2004, 03:40 PM
FLUTE HEAD's Avatar
Gold Member
THANKS, I'LL TRY TO E-MAIL HIM ABOUT ONE. I can't believe how hard it is to find these.
Old 08-17-2004, 04:52 PM
Gold Member
marvinstov is on a distinguished road
I have a Plitron that might work for you. I could sell it for $60.00, you pay the shipping. It is Plitron #757027201. Check it out and let me know. It's new, never used.
Marv
Old 08-17-2004, 05:04 PM
Gold Member
Oh yea, I just built another transformer, a kit from Toroid.com. They come with the primary done, all you do is calculate the secondary and buy your own magnet wire and make the secondary. It is a little cheaper than buying one already finished but fun if you are looking at learning something about calculations for transformers. Comes with formulas for calculating what you need for the secondary. Only takes a couple hours to calculate and wind it.
The one I offered in the previous post is a real piece of work, center is potted, best looking toroid transformer I have ever bought.
Marv
Old 08-17-2004, 05:07 PM
FLUTE HEAD's Avatar
Gold Member
Sounds Like 20v Secondary @ 20 Amps Output. Where Are Located At? (for Shipping Reasons)
Old 08-17-2004, 07:56 PM
Gold Member
I'm located in Florida. I believe it is 20 VDC at 20 amps wired in parallel. There are two primary windings and two secondary windings. The only thing I have done is power it up and test the voltages.
Marv
ID:	3189   Click image for larger version
Old 08-17-2004, 08:18 PM
FLUTE HEAD's Avatar
Gold Member
Appreciate the offer but I wanted to get closer to the mximum volts of my driver which is 35. Wanted somewhere around 28vdc. Hey Marv, what are they calling the toroidal trans on toroid.com? There were alot of different types. I tried to look into there standard transf., just to purchase one but kinda got confused. Oh, heres a thought, what about some of those "harbor freight tools" .com battery chargers. You can get some 24v 12 amp output for like $40.00. Know anyone thats used a battery charger? thanks matt. Someone else on this site also mentioned a microwave.
Old 08-17-2004, 09:24 PM
Gold Member
That's ok. You mentioned a 20VAC transformer in your initial post. I got a 400 VA transformer kit (toroid) from Toroid.com and wound the secondary last night for 28VAC, gave me 37.7 VDC with the bridge and cap. Magnet wire cost me $21 (12 AWG) plus shipping for 50 ft. Only used 40ft. You would probably want a bigger one for the amps you need. Toroidal refers to the shape of the transformer. Donut shaped compared to the regular square ones. Toroid.com seems ok. Took about 4 days to get the kit. Don't remember what the shipping was but came UPS Ground. I haven't tried a battery charger but I'm sure you could modify the transformer in one to work for you. I have been reading up on the microwave transformers and most people take out the secondary winding because it is really high voltage (some around 8,000), and rewind the secondary to suit their needs. I just got one to play with and they are about the right size for a good power supply but seem like a lot of trouble to make them work for the voltages we are looking for. Fun to play with though as long as you are VERY careful with the high voltages. If you change your mind, let me know, I don't have any plans for this one.
Marv
Old 08-18-2004, 08:47 AM
FLUTE HEAD's Avatar
Gold Member
The 20vac is, from what I understand, the callout for the secondary. This number times 1.4 will = the output voltage of the transformer in volts DC. Hope this is correct
How to wire a toroidal transformer..need advice bgolash General Electronics Discussion 15 11-12-2007 08:22 PM
Microwave transformer built power supply TinkerDJ General Electronics Discussion 64 08-13-2005 06:19 AM
RS232 failure to send in XON/XOFF, hangs WAITING, thermally caused. gar Haas Mills 3 05-27-2005 07:44 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
Connecting power transformer to 3 phase keithorr General Electronics Discussion 3 12-17-2004 01:52 AM
