For my control box I have one 110V line in. I was wondering if that one line with a 20A circuit would be enough power to turn on the control box, spindle, and coolant? I didn't know if that would be to much for on circuit to handle. Also what is the common gage of wire for a usb cord to supply 5V@500ma? I was going to use 22g. |
Monte |
| it is for an X2 minmill. It has a 4/5hp motor on it. I am using the probotix 3 axis kit with a 24V 4.5A power supply. I also am using the cnc4pc c11 REL1.1 board. It has a usb cord to it along with a 5v@2a and 12v@1a power supply. The last part of the equation is the coolant pump is from grizzly. It is the 3 gal kit that they sell. |
| You should be fine with the single circuit. One thing you can do is to convert all your voltage and current ratings to watts. Volts X Amps = Watts, then add up to get total wattage and divide by 110 to get total Amps. Your spindle of 4/5 HP will not draw more current than the fuse right there under the speed control, probably 5 amp. 24 V 4.5 A = 108 5 V 2 A = 10 12 V 1 A = 12 4/5 HP (aprox) 600 coolant pump (a guess) 200 ----- total wattage 930 call it 1000 watts for a little overhead so you have about 8.3 amps. Sounds like a good setup. Have fun Steve |
| 110v single phase bridgeport motor swap | stanglou | General Metal Working Machines | 22 | 10-13-2011 06:41 PM |
| Using USA 110V Equipment on Euro 220V Mains! | diarmaid | General Electronics Discussion | 120 | 01-18-2010 02:49 PM |
| Power one Power Supply | teamtexas | General Electronics Discussion | 3 | 10-13-2007 05:05 PM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| E-stop, Interrupt The 110v Ac Or 28v Dc? | Mr.Chips | General Electronics Discussion | 1 | 02-06-2007 08:49 AM |
