I guess the only dumb question is the one not asked. I am finally getting back to my CNC project and I'm second guessing my grounds. I just want to be sure everything is OK before I smoke something expensive. I'm using Keiling brushed DC motors, Gecko 320's and a homebuilt powersupply. Everything resides in a big steel enclosure. The ground wire from the wire supplying AC current is connected to the case. The power supply's negative terminal from the capacitor is also grounded to the case. Finally the green lead from each of my DC motors are connected to the case. Is this correct? Thanks for your help -Dan |
| Don't forget to ground the shielded lines from the drivers to the stepper motors, but only at the driver ends. Don't ground the shielding at the stepper end. OK it time to post some pictures for Show and Tell. Good luck |
Monte |
| And all shields. Al.
| Monte |
| All metallic structures and enclosures are all bonded together. Al.
| I guess it's the same for house wiring, the ground and neutrals are bonded together. Monte |
| I should point out this is my personal philosophy on Non-Isolated system, as opposed to complete isolation between systems. After all safety concerns are addressed, it is a matter of personal preference. I am not declaring either way as right and wrong. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 04-11-2008 at 10:26 AM. |
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 05:13 AM |
| Power supply | auvecu | CNCzone Club House | 0 | 07-18-2007 01:21 AM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| Great Site for Power Supply Basics! | Joe Petro | General Electronics Discussion | 2 | 01-11-2006 06:49 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 02:56 PM |
