Old 04-08-2008, 07:45 AM
SPEEDRE is on a distinguished road
Question What Wire To Use?
What's a good wire size for motor connections? I have on hand 4 conductor telephone wire, solid not stranded, round not flat, is that suitable for use to make connections from the motor to the controller box? Need help I want to connect it up and start it up.
Old 04-11-2008, 07:08 AM
vger's Avatar
vger is on a distinguished road
I used wire intended for connecting trailer lights. Not sheilded but hasn't presented problems. It's available at auto parts stores like "Pep Boys" in a 25' length for under $15 and is quite a bit heavier (16ga I think) than phone wire. It's a 4 conductor color coded ribbon cable that flexes easily.
Best of luck
Steve
Old 04-11-2008, 07:22 AM
TimTheToolMan is on a distinguished road
How much current (Amps) does the motor draw?
Tim
Old 04-11-2008, 07:43 AM
As for the voltage issue, what ever a heavy duty servo motor draws. I'd say low voltage wire, but I've solved that issue. Bought some stranded 22 AWG 4 con. on EBay. Thank you for your replies they were helpful.
Wire Pulgs and Wire JerryFlyGuy General Electronics Discussion 7 03-04-2006 10:57 PM
Very General ? 4-Wire/6-Wire cwoodall Stepper Motors and Drives 7 08-27-2005 05:52 PM
any suggestions? Vo_Tech CNCzone Club House 2 01-31-2005 07:49 AM
suggestions? cncagain General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 09:42 PM
suggestions DDM DIY-CNC Router Table Machines 3 12-15-2003 07:24 AM
