Old 08-12-2004, 05:52 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Help find terminal connector type for this stepper
I got some steppers on a flea market, they where taken from printers.
This thread discuss them http://www.cnczone.com/forums/showth...ht=japan+servo
)Japan Servo 85 oz-in 400 Steps/Rev . $29/ea, (- and if you want to see what a quality motor looks like inside, here is the dis-assembled motor, showing the clean design and double stack with ball-bearing construction.)
Japan Servo TYPE KP56QM2-001, with Ball Bearings on each end of shaft. (note, unless you burn out the windings, and this takes at least a little effort, the only failure mode in step motors is bearing failure - which is easy to remedy as well as rare with Japan ball bearings)
NEMA23 mounting flange: Motor Length = 75mm from flange to rear of case, Motor Diameter = 57mm. Shaft Length = 14mm, Shaft Diameter = 5.9mm
6 Wire CT windings 3.5 ohm - 0 - 3.5 ohm,
Maximum Current: Center tapped - 1.5A , Bipolar, full winding - 1.0A
note: These motors have been carefully removed from surplus assemblies - leads are 75 mm long, and may require extending for some applications. We guarantee your satisfaction with these motors !! Limited quantity available. $29/ea
Leads are short, 75mm, and has some sort of connector on them.
I hope the attachment will help in identifying the connector.
I wish I could use these connectors.
Konstantin
Edit:
I looked closely at the connector and found tiny print "AMP" on one side and "12" on the other. 6 cables connector.
Name:	Stepper terminal.jpg‎
Old 08-16-2004, 01:07 AM
Chagrin is on a distinguished road
http://www.mouser.com/amp
You'll have to dig around a bit to find the right one, though.
Old 10-07-2004, 01:48 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Konstantin,
Did you ever find the correct mating connectors for your steppers? I have some steppers that look to have the same connector. If not, did you find any 6 lead connectors that you could use to re-wire the steppers?
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 10-09-2004, 01:34 PM
Konstantin's Avatar
No, not yet.
I think its best to cut those off and use other type of connectors.
I will need extensions anyway and these conn are PCB type, so I guess I wont need a PCB near the motors in the machine.
Right now I am just hooking it up to my screw clamps directly. Figuring out my electronics.
Konstantin.
Find Vexta stepper parameter tivoidethuong Stepper Motors and Drives 0 04-05-2005 06:59 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
