Old 04-03-2008, 12:03 AM
Shanghyd is on a distinguished road
4 Position Rotary Switch
I have a MIG welder that was equipped with a 4 position rotary switch. The switch was locked up so I decided to take it apart to see what the problem could be. In the disassembly phase the switch came apart suddenly and I didn't have the opportunity to see how it was put together. Is there anyone with a good working knowledge of 4 position rotary switches?
I know this isn't electronic but this is the closest forum I found.
I've posted on 2 welding forums but the interest seems to be in telling me where I went wrong.
Old 04-03-2008, 09:32 AM
Al_The_Man's Avatar
Unfortunately there is no standard for '4 Position Rotary Switches'. It can be an off the shelf configuration, which there are many options, or custom ordered by the equipment manuf.
An idea of what the function is for the switch or a schematic, is required, which I assume you do not have?
If it is a well know unit, you should be able to get the schematic.
Old 04-03-2008, 09:42 AM
I have a thread with pictures at the welding forum.
http://weldingweb.com/showthread.php?t=20529
It's a switch for a mig welder.
Old 04-03-2008, 10:22 AM
samco is on a distinguished road
I would think the schematic would give you the switching sequence. From that you should be able to put it back together.
Old 04-06-2008, 10:39 PM
I ordered a new switch from a supplier. Probably best anyway.
Mazak Rotary Turret Switch reBuild Al_The_Man Product Announcements & Manufacturer News 6 04-11-2007 10:21 AM
Rotary Position device... Belt VS Gearhead 54Oval Mechanical Calculations/Engineering Design 20 03-08-2007 11:49 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Home switch position MrBean DIY-CNC Router Table Machines 1 12-16-2004 06:00 PM
