Old 08-12-2004, 01:30 PM
replicapro is on a distinguished road
Where to find a fuse
I managed to blow a fuse on my Sieg X3 mill and I of course lost the extra one they sent allong with it. It is a 10amp 250v GMA and for the life of me I cant find anyone who sells a replacement. Even mouser electronics doesnt carry it.
Any one know who sells them?
Old 08-12-2004, 02:12 PM
Gold Member
Ken_Shea is on a distinguished road
This company does list them and their resellers.
http://www.philmore-datak.com/fuses,_holders.htm
Ken
Old 08-12-2004, 03:27 PM
sendkeys is on a distinguished road
if you dont find someone might be a good idea to scan a picture in . if its just a normal glass automotive type fuse. would be easy to help you hunt down.
Old 08-12-2004, 04:57 PM
Gold Member
marvinstov is on a distinguished road
It is the standard glass automotive type, 20mm long. Try AutoZone or Radio Shack.
Old 08-12-2004, 05:19 PM
I tried radio shack and a local auto parts store.
The problem is the fuse is GMA body style and 250 v. I dont see why I cant use a 125 volt fuse since im only supplying 115v, but the combination of 10amp and 250 volts in this body size just doesnt seem to exsist. I looked at the weblink above and it wasnt there, those were AG3 body styles which is thicker in diameter and longer. I cant understand why Sieg would choose a fuse so uncommon. Even after I replace it I have to figure out why it blew. I have a suspicion it was due to metal dust in the electronics compartment which I used an air blower to clean after the fuse blew. I even tried the fuse from my sieg lathe which blew right away because its 7.5 amps.
Old 08-12-2004, 06:22 PM
try
http://www.digikey.com/scripts/DkSea...S&Cat=31916779
has them
part F166-ND ect.
looks like you got to buy 5 then i think under so much money has a handle fee... alot of money for a fuse haha
but if you have a multimeter and see if its really 120 volts.(allmost 99.9% it will be) then there should be no reason that you need 250. other maybe it was cheaper or they deal with 240 motors, so they just used same fuses they had laying around
Old 08-12-2004, 07:48 PM
Gold Member
You must not have looked very hard replicapro, GMA 250 volt 10 amp part number EF1100.
Old 08-12-2004, 08:19 PM
found it http://www.cablesandconnectors.com/024001.HTM
Old 08-12-2004, 08:29 PM
Al_The_Man's Avatar
On the subject of voltage rating for fuses, The voltage rating can be at least equal to or greater than the circuit voltage It can be higher, but never lower. The voltage rating determines the ability of the fuse to supress internal arcing that occurs when a fuse link melts and an arc is produced, This is especially important when used on DC.
Al
Old 10-26-2004, 08:29 PM
Sanghera is on a distinguished road
So how do you tell which fuse when thinking about amperes?
york and lancaster couny i can not find anyone harolda Mentors & Apprentice Locator 3 08-21-2006 10:37 AM
Please help find good CNC... dino-new General Metalwork Discussion 11 01-13-2005 05:24 AM
The most useful software that I cant find! berin General CAM Discussion 3 12-10-2004 11:38 AM
Where to find surplus Tslots or 80/20 samualt 80/20, TSLOTS and other Aluminum Framing Systems 8 11-05-2004 01:04 PM
Find and Replace HuFlungDung OneCNC 12 05-12-2003 06:05 PM
