Old 03-29-2008, 01:43 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Boring out ac motor rotor?
How much will the motor be affected if I were to bore out the rotor of a ac induction motor to fit a thicker shaft?
Now the shaft is 30mm the aluminum starts at 50mm it would be nice to bore it to 48mm.
Here is a cutaway, I want to get as close to the cast aluminum conductors (fins) as possible.
http://www.ieee-kc.org/images/motors...%20cutaway.jpg
Dennis
Old 03-29-2008, 02:22 PM
Al_The_Man's Avatar
I would imagine that you should be OK but if you are cutting into the lamination part, it may influence the stator specs.
Why do you have to do it that way, is there no way you can sleeve the existing shaft?
Also you bearings and bearing housing will have to be increased, no?
Old 03-30-2008, 01:23 PM
DennisCNC's Avatar
I need to have another shaft going through the center of the motor shaft. It will have different end plates for the bearings. Off to experimenting will post back what I come up with.
Dennis
Old 04-01-2008, 06:03 AM
vger's Avatar
vger is on a distinguished road
Dennis,
Are you looking at doing a concentric shaft counter rotating system ?? I have to periodicly balance at large counter rotating coal crusher system (two 200 HP motors) but it is fortunately belt driven. It would really be a pain if it were direct drive.
Steve
Old 04-01-2008, 06:41 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Perhaps for a drawbar?
Lee
Milling heli rotor blade daddyhobby WoodWorking 7 04-30-2008 01:34 AM
Ever heard about Star Rotor engines? erd39030 I.C. Engines 14 01-23-2008 03:10 PM
Anyone make their own rotor blades? CNCRob Parts for Radio Control Models 2 11-07-2005 08:33 PM
RFQ for simple brake rotor modification gmader Employment Opportunity 0 08-18-2005 12:00 PM
Remagnetizing stepper motor rotor Konstantin General Electronics Discussion 2 04-11-2004 08:47 AM
