Old 03-21-2008, 09:05 AM
kentrob11 is on a distinguished road
Need motor advice for a project...
I am currently designing a water movement device for aquaria and I was hoping to get some advice on which motor to use. Basically, it's going to be a motor mounted above the water surface with a titanium shaft extended down about 10" into the water with a 2" tall x 3" diameter paddle impeller on the end, encased in a 2.25" x 3.25 " cylinder case. It will pull water up from the bottom and disperse it our of a large opening in the side. I'm looking for a compact and enclosed motor that I imagine should be capable of around 1500 or so RPMs and not be too expensive...Any ideas? I'm open to suggestions on appropriate RPM speeds as well...thanks!
Advice on motor selection andrew888 RC Robotics & Autonomous Robots 10 12-19-2007 08:30 AM
Need some advice on my project sigipa Mechanical Calculations/Engineering Design 9 09-16-2007 11:43 AM
New motor and VFD, need advice bilinghm Phase Converters and VFD 23 04-11-2007 11:20 PM
Servo motor build project... WilliamD General Electronics Discussion 13 11-27-2006 01:35 PM
Will a Stepper Motor be OK for this project ? Delboy Stepper Motors and Drives 6 05-08-2006 05:50 AM
