Old 03-20-2008, 04:48 PM
jonathanupr is on a distinguished road
Will 230VDC work on a 200/220VDC Daewoo system?
I have a question in regards to the power voltage input to our cnc machine. We just purchased a Daewoo (fanuc control) Puma from Canada. The required voltage input is stated as 200/220 volts & 50/60 hz (max of 175 amps).
My question is: we have 480 vdc throughout our building. I have purchased a 480vdc to 240vdc transformer to input to the machine. I was hoping I'd be able to tap down to the 220vdc range but can only get down to 230vdc. Will 230vdc still be too high?
I am used to seeing a +/- 15 vdc input acceptance.
I am hoping this will work, but do not want to jeopardize the electrical system of an expensive machine. I could always get a custom made transformer to input 220vdc (though I'd have to uninstall the present transformer).
Thanks.
Old 03-20-2008, 06:14 PM
Al_The_Man's Avatar
I have always found that Fanuc state 200vac supply +-10%,
Go as high a voltage tap setting as you can on the primary taps, this will give you lower secondary.
You should be able to get a 220v sec. or use a buck/boost transformer.
Old 03-20-2008, 08:49 PM
thanks for the reply...
to clarify the best method to go about this... it seems that while I still have the capability to switch out transformers (with a re-stocking fee of course), it would be best to use a 480V to 208V transformer.
otherwise I'd need to get a buck-boost transformer (which seems like overhead).
Unless, I can take a 480v to 240v transformer and get the 240v down to 220v...which seems unlikely, unless I could try tapping down the primary leads as suggested.
Daewoo puma 8s mroy0404 Daewoo/Doosan 3 06-14-2010 01:58 AM
New To Daewoo..... Any Others rolinjunk Daewoo/Doosan 7 02-16-2009 04:05 PM
Daewoo 12L toolendmill Daewoo/Doosan 1 03-07-2007 06:09 PM
Daewoo ACE-H80 Cncjunkie Daewoo/Doosan 7 03-13-2006 06:55 AM
DaeWoo Lynx 200 GL fjd Daewoo/Doosan 5 10-29-2005 09:43 PM
