Hi all, I was just wondering how to properly mount a driver board on wood or metal. I have a Xylotex board, I know that won't make much difference. I read on the pdf at the Xylotex website that you have to use plastic washers, I'm pretty sure you can use ordinary metal screws. I'm not sure if something will go wrong if the screw touches the metal on the board accidentally. Thank you soo much everyone. I really appreciate it. Last edited by Sanghera; 08-03-2004 at 11:43 PM. |
| Electronic stores sell little plastic spacers to lift the board and clear the component tails, and soft insulating washers to go under the metal screw heads. Boards are pretty robust, so as long as you don't use a gorilla grip to crank up the screws you will be fine.
__________________ Regards, Mark www.wrathall.com |
| I went the really "Nervous-Nelly" route. Mounted to a piece of scrap plastic (used to be top cover for a scanner) using nylon machine screws, spacers, and nuts. Then mounted that assembly to the bottom of a pc case. I'll add a pictute if that helps (gotta find it). Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| I usually use dowel rod (wood or plastic) cut to length and ends drilled and tapped as standoffs. A cheap source for light duty rod is plastic clothes hangers. Pretty soft and very easy to work with common handtools. It's no good for hi-temp use (softens in boiling water), but for a quick fix it works. I'm careful about checking screw heads for mechanical and electrical interference on the boards. If there is any question I use nylon. robotic regards, Tom = = = = = "Because a man thinks with his d***, a woman d***s with his thinking." - - Jennifer Wiley-Cordone |
| Thanks guys. I have some nice little plastic washers, and I will probably use wooden dowel to raise the board, and then put a metal screw in it. I'm not sure about using metal scews. I think I should be safe with this method. I HOPE!!!!!! Wow, this is an awesome forum and website. I just wait overnight, and bam, I have so much information. You guys are great. Thank you very much for all of your help. I really appreciate it guys. Last edited by Sanghera; 08-04-2004 at 12:17 PM. |
| help with boards | mocnc | General Electronics Discussion | 15 | 02-17-2005 08:18 PM |
| Video of my CNC milling circuit boards. | MrBean | DIY-CNC Router Table Machines | 21 | 12-23-2004 04:38 AM |
| Electronic circuit copyright. | ynneb | General Electronics Discussion | 5 | 06-17-2004 10:56 AM |
| question about 2 X 2axis boards | Stevie | General Electronics Discussion | 5 | 03-14-2004 06:39 PM |
| Help w/ e-stop circuit design | owhite | General Electronics Discussion | 4 | 03-07-2004 08:16 AM |
