Old 08-02-2004, 10:24 AM
I'm getten there!
dmgdesigns is on a distinguished road
Transformer help
I have 3 Relience E712 Servos. Will this transformer provide enough current? Should I just get a 12Kva? One of the many things that confuse me is the 60v ~22amp output, then it goes on to say 11.5 amp output. I noticed several people on the forum have these motors. What transformers do you use?
BTW is this a good price?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
My machine has 53"X34"X6" travel made of alu. plate thomson bearings 1" on X 3/4 on Y I added the material, motors, router, etc and the gantry weighs about 130 lbs. I plan on cutting 3/4 Oak, Mdf, Pine.
Mark
DMG Designs
League City, Texas
Old 08-02-2004, 03:25 PM
Gold Member
marvinstov is on a distinguished road
I think there is a thread here somewhere discussing this particular transformer, can't remember if it's here or the Yahoo CCED forum. Sorry but that's all I can help you with since I'm not one of the all knowing and seers of electrons. (But I'm still trying to learn)
Marv
Old 08-02-2004, 04:22 PM
arvidb is on a distinguished road
Originally Posted by dmgdesigns
*snip* One of the many things that confuse me is the 60v ~22amp output, then it goes on to say 11.5 amp output.*snip*
It says 22 amps at 44.5 VAC output. After rectification this becomes at best about 15.5 A at 60 VDC. (44.5 VAC * sqrt(2) and 22 A / sqrt(2) to make output power = input power.)
Also the text says "11.50 DC amps while running cool in the chassis". So I guess it either not runs cool at 15.5 A, or that the voltage have dropped a few volts at that current, or both .
Arvid
Old 08-02-2004, 05:47 PM
jfirey is on a distinguished road
I am the Ebay seller on these. Arvidb explains the conversion (and conservation) or energy quite well. The "11.50 DC amps while running cool in the chassis", helps to define the capacity. Many commercial transformers will run quite hot at full load. I have issues with the industry standard definitionof ful load. Many xformer suppliers rate FLA based on max core and insulation temperature, resulting in a HOT xformer. These are wound of much smaller wire gauges, resulting in high copper (I2R) losses dissipated as heat.
If your application can allow for some heat, though nowhere near as bad as commercial xformers, then you could run this for a 22~25 Amp DC load. Beyond this, you push the core design. The limits are the wire size (which is well oversized) and the core, which is good to just over 1900VA.
Old 08-02-2004, 05:59 PM
BTW, The 11.5 Amp is the DC load, after a bridge rec and a cap, given a form factor of 1.8 due to the pulse current output using this style of rectification.
Old 08-02-2004, 06:06 PM
Gold Member
CRFultz is on a distinguished road
jfirey,
will you be selling more of these?
I won't be after this one ..Mark has it...but i will be needing one soon..
Chuck
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Old 08-02-2004, 09:17 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
I have those motors too and will be using this power supply:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5712776324
It actually reads 52VDC (unless my meter is off). It is a switching supply but well made. Marisse said that switchers are just fine....just add the filter cap 20000uf or maybe two in parallel. This supply came already and performs great with these motors...used my existing g320 geckos.
one nice thing, it has an amp readout on the front that tells you what you are drawing under different loads.
Old 08-02-2004, 09:48 PM
CRFultz/all,
No problem, I have several on-hand. Send me a PM, and let me know what current/voltage you need. These are handwound, so I wind them as needed, for whatever voltage/current needed.
Fair warning: I tend to wind them generously on the wire gauge. I have been beat up on this in the past. I won't sell little things that run so hot you can cook with them.
They don't run hot, they don't drop voltage much, and they'll handle a lot more load than I'll admit to.
My Rant
They are wound by hand, with multifilar winding techniques passed down for several generations. Every winding and each wire laid in as tight as possible. I do believe that any machines built can wind xformers like these. The advantages of multifilar winding techniques are not 'mainstream' because they cannot be automated. Combined with flat wire and new age strip laminated toroidal cores, these are the best xformers I can produce, and they are not available elsewhere.
I built them for my CNC/servo stuff and though some others out there might appreciate them as well.
The inductance is strong and each one is tested and trimmed for voltage before shipped.
Be aware, when we get above the ~48VDC range, you can get much more seriously zapped. Please be sure you are being safe.
Switchers:
Switchers will work fine, and it looks like the one above is a good deal. It is not always easy to find a high current switcher that will provide 100% duty cycle. It also involves waiting for one to show up on Ebay, or in your local surplus shop and then taking your chances on whether it works or not.
So if you can't find a switcher, battery bank, forklift charger, or the one you got doesn't work, these are available. And you don't have to bathe in high frequency EMF.
Old 08-02-2004, 09:59 PM
Bloy2004's Avatar
Fumbling Machinist
yah! those toroids are nice!
I got one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3823295926
on chance I could use it, but after applying 120VAC to the primary and rectifying it I ended up with 90+ VDC. Way too much, but have it until I learn how to bring the voltage down, or if I ever need the 90 VDC.
It is HUGE!
Old 08-02-2004, 10:07 PM
Bloy,
I saw those also. I thought about getting some, but I prefer to run with my own. It wouldn't be right to build them and not use them, eh?
Bloy: Put a variac in front of this you'll have whatever voltage you need. Just turn it up and down! When they are gone, I'll still be here.
DO NOT USE A VARIAC WITHOUT AN ISOLATION TRANSFORMER. You risk become the conductor is certain circumstances.
Old 08-02-2004, 10:16 PM
Bloy2004's Avatar
Fumbling Machinist
hah! Yah!...that's what I meant about "learning to lower the voltage" ! DANGER DANGER! I've been looking for a good buy on a variac....and the isolation trnsformer, But I really like that MPR25 supply.
By the way, at this time there aren't any of those big, huge, heavy toroids offered on ebay....they may be out.
Old 08-03-2004, 06:35 AM
I'm getten there!
Thanks for the help.
What? Right over my head.
This brings up another question, rec. and cap. V & A rating. Should the ratings be just enough to cover the max load that will ever be used and avaiable or it does not matter as long as it will cover the load?
Mark
DMG Designs
League City, Texas
How to wire a toroidal transformer..need advice bgolash General Electronics Discussion 15 11-12-2007 08:22 PM
Microwave transformer built power supply TinkerDJ General Electronics Discussion 64 08-13-2005 06:19 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
Connecting power transformer to 3 phase keithorr General Electronics Discussion 3 12-17-2004 01:52 AM
Sola CVDC transformer wiring: Please Help Mini Miller General Electronics Discussion 7 11-30-2004 11:46 PM
