Old 03-14-2008, 09:04 AM
leandrot is on a distinguished road
hel with DC motor drive connections
Hello
I recently bought two KBLC19 6amps DC motor drives on ebay. Both came with and overboard control board called Peco model 5900-800-01 wich I was unable to find any manuals or connection diagrams on the web
That Peco control board arealy came with speed potentiometer, but I need to know about the forward/reverse and fast/slow connections on it...
I guess for the fwd/rev I should connect a switch betwen the 'fwd/rev' and the 'commom' wire. But as a newbie I'm afraid of burning out the controller if my theory is not correct
So please someone give me any advice on this. Attached to this post is an photo of the controler
Thanks!
Old 03-14-2008, 09:13 AM
Al_The_Man's Avatar
It would appear the fast/slow fwd/rev and inhibit are just active low/high with respect to the common terminal, IOW open would be one condition and connection to common would be the second.
The other four look like 2/power in 2/motor .
Old 03-14-2008, 10:48 AM
thanks Al, I will connect that way and see what happens
now just one more question on these controlers... is the 'inhibit' function a dynamic brake for the motor?
Old 03-14-2008, 10:54 AM
Al_The_Man's Avatar
Not usually, it often just turns off the drivers and the motor free wheels.
Old 06-04-2010, 01:22 PM
BSawyer486 is on a distinguished road
Hey Al,
I was hoping to get you to look at the above picture one more time and tell me what exactly the overboard does. "is it needed for total efficiency of this board?".
I can figure out the wiring if I remove the overboard but with all the other connections that are on the PECO board I am lost. The 20 pin=10pin fast /10pin slow? like this [::::::::::] have me confused. I have been unable to find a schematic to this board so I was hoping to get some help from you.
And thanks to "leandrot" for the use of your picture.
Thank You,
Bruce
Old 06-04-2010, 01:44 PM
Al_The_Man's Avatar
The board does not show up in the KB list of options for this model, It appears to be an after-market board, it appears to have an analog output so I am not sure what function the board is supposed to achieve?
Generally the one used is a analogue signal isolation board or 3rd party PWM to analogue.
Old 06-04-2010, 02:09 PM
Ok, So I am guessing I could probably connect it up with the PECO board removed just like the MC-60 treadmill control board as the connections on the base board are layed out the same. L1, L2, common, P1, P2, P3 and then two other connections that would be the DC output. Would you semi-agree with that statement?
Thank You,
Bruce
Old 06-04-2010, 02:15 PM
Al_The_Man's Avatar
Sounds about right.
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
with a Dover air Spindle, DMM-1000 drive connections DiamondGirl Servo Motors and Drives 1 02-18-2008 07:56 PM
Yaskawa Minertia motor connections belli Servo Motors and Drives 7 01-28-2007 10:35 PM
Pin connections for DNC to 4020 Fudd Fadal 5 04-04-2006 02:40 PM
201 connections rickwinters Gecko Drives 0 01-15-2005 01:37 PM
