Old 03-13-2008, 10:50 AM
Beginagain@60 is on a distinguished road
What about Amps
My first post, I so not want to offend anyone.
I understand the voltage choices, thanks to these post, but how do I choose the amperage the supply should be capable of. My 3 Bipolar motors are rated 3.2v and 2.8amp each, I am thinking 24v supply. Any Ideas
Old 03-13-2008, 04:51 PM
ger21's Avatar
It depends on the drives you'll be using. With Geckos, you need 2/3 of the motors rated current per motor times the number of motors. You can go as high as you want, as the drive only draws what it needs. In your case, with Gecko drives, a 6 amp supply would work. I'd go for about 10 amps.
Old 03-13-2008, 05:43 PM
Supply size
Gerry.
Sounds good. Thanks for the info, and thanks for letting me jump in.
Terry
Help with servomotor amps Ross77 Servo Motors and Drives 0 11-08-2007 03:08 PM
figurieng amps cueshark General Electronics Discussion 3 03-08-2007 11:03 AM
2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... kochevnik Stepper Motors and Drives 6 10-22-2006 10:48 PM
How many amps ? bgolash General Electronics Discussion 1 03-09-2006 07:48 PM
Howto find input amps, from output amps on transformer? sendkeys General Electronics Discussion 7 07-14-2004 07:13 PM
